Reverse Engineering the Macintosh LC III Logicboard
Looks like you'll have to file the 96-pin one and cut into a 21-pin to get the 18-pin extension… Maybe a hot-wire would work for that.
its very awesome to see the home made LCIII board is finally working/booting :)
it really has been awesome to see all the reverse engineering going on here, some proper hard work by some very skilled people!
I look forward to further progress and seeing what else gets done in the future :)
Do you plan on publishing the files someday? Along with some netlist RE it would be useful in OpenBoardView for troubleshooting existing boards…
Yes, Once the board has been finalized (and hopefully a few sold to recoup my costs) the layout files will be published
Do you recall who that was?
I fount this attempt at REing their format but it's not finished. I was looking into adding import for OpenBoardView…
I don't i'm afraid, it was a very breif discuassion I saw on the RetroTinkering discord server some months ago
Perhaps a Dremel-type tool on a mount with a "diamond" cutting wheel?
I've used that set up to separate paired 30-pin SIMM sockets.
Easiest way to do it is with a razor saw from X-Acto or preferably, a pull stroke fine cutting Japanese type flush cut/dovetailing saw. Three 96pin slots make two 130pin slots.
When buying "96" position slots, make sure all 96 pins are implemented. It's easy to wind up with only two rows/64 pins on useless connectors.
Did you look at the DIN connector yet? There are 3x16 ones on aliexpress that might be cut in two halves I suppose (one requiring some more filing on the plastic key). It should be possible to make a small PCB as cutting rig with marks on the silk screen.
I haven't looked at it much yet, I did purchase some 120pin connectors wit the intention of cutting slot out of them but your method seems a little simpler
I Need to order some stuff from aliexpress tonight so I'll order some of those and give it a go!
@max1zzz: This is amazing work! I'd like to ask you a favor, would you be able to share a JPG or PDF of the board layers for this lower section of the LC III motherboard near the internal HD connector? This unfortunate board underwent a Chernobyl-type situation with the battery that obliterated the traces and vias in this portion of the board. I would like to see if I can repair it by running some wires, but the board is so destroyed in this area that I can't make out where the traces used to go.
@max1zzz: Thanks! This will help prove or disprove some of my theories!
So I've been looking at the schematics from Bomarc and found out that the PDS slot is like a giant breadboard with all the important signals. How convenient! I've been using my multimeter and have just finished buzzing out all the data lines from the ROM chips to the PDS slot. All except one were good, so I am pleased that at this point that most of the data lines from the ROM seem to be okay, which was my primary concern. I'm betting trace damage will be clustered in the conduits to U35/36/37, which at this point I do not know the purpose of, although I am guessing they multiplex the address lines, so they must be fairly important to get right.
Thank you, guys! I've just done the first pass of figuring out where all the likely broken traces go and fixing this guy is gonna be a doozy -- some 35 to 40 different bypass wires will be needed, at least! This board is gonna have to look like one of those wire-wrapped computers from the 60s before it ever boots again... 😁
I’m late to the party and you may have covered this already. But where do you get the components to populate these new mother boards? New? Nos? Salvaged parts? A combination?
I'll always be a combination or purely salvaged as these boards contain a number of custom IC's (The memory controller, clock chip, CULTDAC, DFAC and EGRET) so you'll always need a donor board for these. Initially when building these I was always replacing the passives with new but in the end I actually found it is much quicker and easier to just move all the passives over form the donor boards
The board layout, Gerbers, Copper layout and board scans are now available!
As with the LCI board this is provided under a non-commercial license however if you provide repair services and want to provide these boards (Or want to use them for any other commercial purpose) please contact me
