Trash80toHP_Mini
NIGHT STALKER
Looks magenta, that rocks!
Yep. I would take a BGA over a fine pitched QFP any day! The BGA is waaaay easier to solderI swear thoses small pitched QFPs is what made humanity create BGAs![]()
I cut the trace to either side of it and ran a bodge wire, I did consider drilling it but one side of that VIA is under one of the VRAM IC's which I didn't fancy desoldering!Did you drill out the shorted thruhole and patch wire the connections or cut traces and patch?
Also not what the best way to check the VRAM simm is working
Ahh ok, I get thousands with the VRAM stick installed and only 256 without, so it must be working thenSee how many colours it'll let you select in the Monitors control panel?
That PCB looks so stylish in purple...
Ahh ok, I get thousands with the VRAM stick installed and only 256 without, so it must be working then![]()
I know, can't decide if I'm doing the final boards in black of if I'll stick with purple....
