Alex
Hello
My 150 starts up the moment its original power adapter is plugged in.
(NOTE: removable battery is not connected but I can test with it plugged in even though the battery is dead. The internal PRAM battery has been desoldered as it was just beginning to leak).
I read in another thread on 68kmla that I should not use the Shutdown menu in similar cases as it might make it contentious to power on the machine in the future.
Secondary (related?) issue: After the 150 sits idle for a while, the energy saver kicks in and sleeps the screen and HD as expected but on wake (tapping a key on keyboard) the trackball ceases to respond to clicks or scrolling even though the Finder remains working as expected.
Reference: This machine has been reassembled after repairing the display's plastic bezel because it had separated from the display. PRAM battery was removed during repair.
