Macintosh SE/30 logicboard recreation (thread revival)
WillJac
Suggest doing the same for the 3 small PLCC's also as they difficult to solder if no socket is used. Thanks for the update on the board as this is much appreciated.
Doctor69
Hello, I managed to buy new se/30 motherboard made upon r5 Gerber files. Now they're asking for the centroid file for the bottom side. do you know if there's one I can upload? Thank you in advance
Pretty sure the centroid file is just another name for the pick and place file.
Doctor69
Hello, can someone help me checking the correct positioning of these components on rev5 Bolle's SE/30 board? thanks in advance
PCBWAY, to whom I ordered the boards asked to check if everything is OK but I'm no technician.
wottle
Looks like they scratched the board around L11. May want to confirm the traces there weren't damaged. Or see if they can replace it.
