zigzagjoe
Another quick 3D printed widget, this time for a SE/30 LB. I typically have one on my desk with either an original chassis with extension cords or one of caymac's RGBtoHDMIs sent to me by @Jockelill. I figured it was time to give it a little more dignity and protection. Board slides and latches in place and has cutouts for 3M SJ5400 small rubber feet on the bottom. Supports beneath the board allow pressing on the slots and sockets without overly flexing it.
Around 150g of plastic, 230mm * 235mm. If you have good overhang performance, you might be able to print without supports, I turned them on to be safe (but then you'll have a job cleaning out the rails for the LB).
