Bunsen
Admin-Witchfinder-General
I was looking at doing this with Adafruit's 9.7" display (basically the iPad Retina display), since 2048x1536 would be high enough res to be able to upsample a few different resolutions without bad artifacts. But, that relies a lot on a magical third board that could do analog->DisplayPort
The earlier iPad displays do 1024x768 (XGA), which is exactly pixel-double the old Mac 512x342, and will work off cheap ebay driver boards. And the iPad Mini version, at 7.9" diagonal, would fit neatly in the bezel. You can pick up a kit with the driver board and panel for not too many dollars.
10.4" and smaller XGA LCDs were also used in a few laptops, Panasonic Toughbooks for example.
