I noticed that the 8.4" screen chosen was one with an LVDS interface. The same company that makes that screen(Looks like Tianma may have purchased NEC's industrial TFT division?) has the same panels with a TTL interface, which is the more traditional RGB+HVC parallel interface. Those "everything-in-one" controller boards usually have both outputs present, but I'l like to make a more dedicated controller board that doesn't have a ton of unused connectors or need the OSD menu + buttons to work properly.
Actually, I believe for the Color Classic, I can create a whole new analog board + TFT display swap kit. The new analog board would have the TFT driver and backlight, the digital power supplies for the logic board, should be able to handle the "soft" brightness and contrast controls, and maybe even be able to do stereo audio(at least with a LC/Perf 5xx series logic board installed). I was all about 10.4" displays, except those require hacking the bezel and the end result would just not "feel" like a CC anymore. I did some measurements, and the actual viewable image size of the CC's Trinitron is actually very close to the 8.4" actual of the Tianma/NEC panel. Of course some bezel or filler would still be required. I really like the idea of the molded resin which may even be easier with the cylindrical Trinny than with the Spherical CRT of the SE/30.
The only other sticking point is the AC inlet. In order to not make something that less careful people might by chance electrocute themselves with, I'd probably have to convert the power input to a brick or wall-wart; Yuk! Still, there are some very capable slim and compact 12-18V AC/DC wall supplies which could do the job since a lot of the power used by these machines is in the CRT monitor. Also, the total unit weight would be cut by about a third(estimated).
I already ordered a parallel interface version of the 8.4" panel and plan to make a prototype "VGA Monitor" to prove it can work. Any interest out there in me turning this into a replacement CC analog board? I had actually had an idea to make a new rear housing for the CC to repackage it into a slim, flat panel machine, but for now I'll start with the monitor.
