amedeo_68k
Hi everybody, I got an SE/30 with RasterOps Colorboard installed.
The first thing I did is to remove the PRAM battery, the unit works, but needs some recap that I plan to do really soon.
I would like to ask an info about the Rasterops (fw 1.3)
I see that internally the metal plate has a spare side for a VGA DB-15 connector
So I would like to redo the board to connector cable installing a standard VGA port.
Does anyone knows the board side pinout ? ( probably I could test the other port and figure out, but may be I need some config resistor to put in ).
One more question, in another SE/30 I have the Asante MacCon with passthrough, so in theory (please correct me if I'm wrong) electrically I could connect both boards, but mechanically they would not fit, at least I would need a L shaped adaptor, ideas ?
Thank you
Amedeo
Thank you
Amedeo
