Anonymous Freak
I have three Blackbirds. I can make two "good" Blackbirds out of the parts, plus one "pretty crappy" one.
The PCMCIA module sits in the 540c/'LC040/20MB RAM, simply because the PPC won't work with it inserted (pesky RevB cage!) I usually keep one battery in the 540c and one in the PPC 520c. (And yes, I do have an 'expansion bay cover' to cover up the open bay whenever needed.)
So, does that sound like a good setup to the peanut gallery? Or would you all suggest putting the PowerPC in the good screen/high RAM system?
(And if anyone has a spare RevC PCMCIA cage they're not using....... I'd happily trade away my RevB plus my 'spare parts' 520c, plus more if need be.)
Oh, and as for OSes, the 540c/040 is running a bone-stock original 7.1.1 from original 520/520c/540/540c branded floppies (plus my PowerCD driver since it's the CD-ROM drive that looks best with it.) The 520c/PowerPC Is running 8.1 at the moment with an assortment of addons. (RAM Doubler, Speed Doubler, etc.)
- I have two good physical condition cases, one pretty beat up case. (screen side latch snapped so it doesn't stay shut, pretty big chip in the front bottom plastic at the very front where the battery slides in, display lower bezel ("Display Access Cover" in Apple-speak) bottom clips broken, so it doesn't stay on well.) Note that when I got them, each of the three had some problems, I moved all the "bad looking" plastic parts to one chassis.
- Two 520c passive matrix screens, one 540c active matrix screen.
- One 16 MB add-in RAM card, one 8 MB add-in RAM card (which means one machine can be at 20 MB, another at 12 MB, the last at built-in-only 4 MB.)
- Two 250 MB hard drives (which means one system goes without.)
- One PowerPC 603ev/133 MHz CPU card, two stock 68LC040/33 MHz CPU cards.
- Two decent-condition (re-celled in 2010) batteries.
- One RevB PCMCIA Expansion Module.
- Two internal 19.2k modems.
