A big Quadra update today.
I was poking around one of the boards this morning looking for broken traces and I found one adjacent to the AT&T DSP. It really didn't look broken at all, but it was. You can't easily tell with the brown PCB. I ran a repair wire over the break:
I then decided to give the board a test, not really expecting anything different. But... as
@Mac84 once said,
it chimed! And not only that, but I got video. It boots off both a disk tools floppy and off a SCSI hard drive. Ethernet works, video and sound work. As far as I can tell, it's fully functional. And it is rocket fast.
The DSP is a secondary system, so I'm surprised that a single break here would prevent the machine from chiming. Another oddity is that the machine will chime, then hang, with no RAM installed - other Macs I've used will chime normally and then immediately death chime. The 840AV
does have a death chime (a quite amusingly silly one at that) but I had to invoke it with Command-Power to hear it.
With many thanks to
@GRudolf94 for their brilliant ATX adapter, which I wouldn't have been able to do without, as my original PSU is dead.
I will look at recapping the PSU and see if this brings it back to life. To be honest, it would probably be more pragmatic to adapt an ATX PSU... but I like the idea of restoring the original components.
I will also turn my attention to the green 840AV board - it has been a bit more seriously ravaged by cap and battery juices, but I ought to try.
