Sweet, thanks. NoPro on the inches. A 3" tank or anti-tank gun is 76.2mm, so your six inch ruler will be twice that for pretty easy scaling. Number associations can be very, very strange things. :
Bolle, have you looked at the mounting ear complications for your layout? I'll get your layout into Illustrator. In the meantime, print it out, paste it up to cardboard and lay that with your wrong angled NIC on top of your GS Card to determine the points of interference.
Looks like you need to convert the mounting holes for your bottom slot connector to the RA connector configuration mirroring your female passthru connector provisions on top?
I wouldn't use headers for power connections, pretty sure they're not reliable enough anyway. I'd add thruholes for soldering nice fat copper jumper wires if anyone wants to overtax PDS Power spec by running more than two cards. Normally I'd say put butterfly traces on outer layer in your layout to be easily cut when adding aux power. But in this case I'd leave both options "open" for a user to make a conscious decision as to which route to take at their own risk. KISS is good CYA is better. [
