Trash80toHP_Mini
NIGHT STALKER
I'm gonna let you guys figure out the black magic, I can no longer afford to spend the time required to buy a clue about electronics.
Meanwhile, I think I'm gonna have a go at the hardware side of things. There's plenty of room to install a hinge of some sort (duct tape will do for prototyping) at the back inside (outside application of a strip of duct tape might work better) of the standard Duo battery pack. I'll be using the retaining slide as the latching mechanism for the front of the FrankenPack.
From this pic you can see the details of the spring/contact plate from the fully enclosed CrapShack battery pack. the positive side bumper is the same thickness as the fully compressed spring on the negative side.
The best bet for this hack will be drilling the spring out of the negative side for the mid-mount config. Doing it that way allows for the connection plate to be mounted backwards so the hump that was to be hammered flat in the original concept becomes a receptacle for the battery's positive terminal.
A minor amount of Dremel work creates five recesses in the sides of the battery pack for the humps-turned-receptacles to significantly increase the effective inside dimensions of the FrankenPack.
The one negative of the stock parts cannibalized from the CrapShack pack is thus transformed to a positive for this configuration.
Once the FrankenPack is inserted into the Duo, all stress on the Duct tape hinge and the front slide/latch is relieved by the tight embrace of the Duo's battery compartment.
My only serious question is the discharge cycle characteristics of off the shelf NiMH cells as opposed to the cells you've sourced, big.
Silly(?) question: given the center spring hack, wouldn't tabbed AA cells work well for a simplified version of the FrankenPack? The tabs would be the connector plates on the ends and the folded over tabs in the center with the spring would ensure good contact every which way I'd think.
No soldering or Dremel work required! ;D
p.s. forgot to mention this: by using off the shelf cells, the FrankenPack disassembles and reassembles easily enough to just use the four position, off the shelf charger five times to refill the FrankenPack and stick a full set of spares into any handy container.
