Sideburn
Hey All,
I rebuilt a test pack for my 2300 and, although it is charging it will not power the machine. it shuts down immediatley when disconnecting the external A/C adapter.
Are the battery types not interchangeable between Duo versions?
I have two packs. One is a model #M7782 and the other is a #M1499
I reebuilt the M7782 pack and I know this is a Type one pack used in the PowerBook Duo 210/230 series originally. Will this pack not work in a PowerBook Duo 2300c?
And is the DS2400 DALLAS SEMI Memory Circuit important? I assume this is used to identify the battery pack type.
