TheIanMan85
You're certainly welcome on the manual. Agreed on the Genius Bar. Looking into the manual it seems to agree with what we've talked about.
As for the power problems, I'd say borrow or buy another known good compatible charger. Hopefully that fixes it. If not you've got yourself a spare compatible with the 1400-Pismo if I recall correctly, plus some (all?) Duos...that's off memory. Someone correct me if I'm wrong. If not it's time to start replacing on the inside.
That's what I've got for the moment! :b&w:
That was from "Internal hard drive does not spin" but the process seems logical for this situation. Didn't read every page, but saw another boot failure flow that had about the same to say.Hard Drive1 Make sure power adapter is connected.
2 Disconnect external SCSI devices.
3 Check hard drive connection.
4 Check connectors for cracks and replace if damaged. 5 Replace hard drive.
6 Replace I/O logic board.
