Pretty remarkable that you did that without a hot air gun. I sure wouldn't have wanted to do that.
Me either, ha!
Yea, that takes some dedication. I would have hot-air gunned it.
Yeah, I would have too if I had a hot air station!
Impressive. The one thing I was amazed at was after taking the plunge, just how easy it is to work with hot air. I won’t fear it again. That being said, your effort was tremendous!
Thanks! This project almost convinced me to look into a hot air station... but I decided that I could get it done with just an iron. Or could I? Read on...
First, I decided to clean up the "junk" board for some practice. It will be great to keep around both for parts, and for reference.
Next, on the good board, I went crazy with the flux paste.
I gotta admit that this part took awhile, and was a bit scary. I had a hard time getting the desoldering alloy to evenly coat each side of the chip. At this point, I was pretty convinced that I had permanently destroyed my SE/30. Why did I mess with it? Would not having sound been that bad?! What was I thinking?!
Eventually I removed it all and started from a clean slate, and the IC popped off a lot faster.
Here's the supposedly bad ASC, removed.
Next, I cleaned up the pads. I thought a couple of them were gone, but I scraped away at them for awhile and sure enough, there were pads! That could explain why the first ASC failed. I am pretty sure that there was continuity... pretty sure. I'll keep the old ASC around. Maybe it's still okay.
Next, I tinned a couple of pads. In this photo I have only tinned one; I ended up removing that and tinning a couple of pads on another side that was easier to get to.
I ran the iron over each of the pins to make sure it was clean.
Next I set the IC in place, and flowed the two tinned pads. The IC settled down on the pads. Next I soldered a pin on the opposite corner, and double-checked that everything was straight. Then, I hit all of the pins with liquid flux, and started soldering the rest of the pins. I thought I could drag-solder everything, but I really struggled with bridges so eventually I just soldered every pin, one at a time. At this point, I was REALLY convinced that my SE/30 was dead for good. Totally hosed.
After cleaning it with alcohol and hitting it with the air compressor, here's what it looked like:
I reassembled it, flipped the power switch, and...
There was a nice, clear chime! Woohoo!
I am doubting the fix a bit - I booted from the ROM and fired up Sim City from a floppy disk. The sounds all work just fine but are pretty bad quality. I think that's just because they're just low-quality samples. Curiously my Bolo or Microsoft Flight Simulator sounds didn't work. I'll get System 7.5.5 booting next, and play some more sounds to confirm, but I am 90 percent sure that the sound issue is fixed.
Thanks for identifying the problem,
@techknight!
