just.in.time
A little late but I’m going to add my two cents. Whatever 68k PowerBook you do get, open the display only once! Get it to a comfortable viewing angle and never close it again. The opening/closing cycles on the old hinges and brittle plastic is what generally destroys these things. I keep all my PowerBooks and Clamshell iBook open on a couple display shelves I bought from IKEA. If you buy one that looks to be in decent shape it should survive one opening. With any of these, make sure they are in working order before buying and that there aren’t any battery leakage/corrosion issues.
As for specific machine to buy, I’d say the 180c, 540c, or 190cs. To my knowledge the tunneling issue doesn’t really happen on color active matrix panels or any of the passive matrix panels.
The 180c should be decently reliable and the pinnacle of the original PowerBook design. 68030, FPU, and a RAM ceiling of (I believe) 12mb. In theory this machine should be great on 7.5.5. But I’ve never owned one
For a machine I do own, the 540c. Hands down one of the most beautiful displays of the era... I’d argue even more pop in 2019 than the panel of my 5300ce (which is in great shape as well). Plus it has stereo speakers, Ethernet, a high enough RAM ceiling to run OS 8.1 confidently, and the first trackpad. The weakest point (remember, you bought one with good plastics and ONLY opened it once and never closed it again) will probably be the power supply. I hear they are a PITA to open, but are fixable.
Finally, the 190cs. Honestly, it’s reliability will be primarily because it was the newest 68k PowerBook available. It has color, but only passive matrix. Will definitely appear washed out and slow to refresh compared to the 540c (and probably even the 180c’s panel). BUT it does have onboard PC Card slots. No nead for expensive cages (looking at you 5xx series). It’s weakest point will probably be the DC jack (shared with the 5300). However, it seems to be an easy fix of just resoldering it down. I had to do it for my 5300cs way back in the day and now I need to do it for a 5300ce I’m restoring.
