Sound Manager patch for Mobius and Carrera 040 accelerators?
ktkm
I have been researching the crackling sound issues with my Mobius card before but never reached any conclusion on how to fix it.
This old Google thread mentions something about a patched version of “Sound Manager”. Is true or just a myth?
ktkm
At https://www.micromac.com/software/software.html there's a download called "Carrera040 v1.8 (latest software with sound fix)".
Might be worth checking out.
Thanks! The 1.8 is the one I’m using, except I use the one @Bolle supplied me with that works with SE/30. However, It doesn't seem to fix the Mobius sound issues.
Thanks! Missed this one since I most of the time use System 7.1. I’m going to try the patch with system 7.5.3.
“This problem was previously corrected by replacing the Sound Manager extension and Sound control panel of System 7.1.”
The quote is from the same link you just gave me. It would be nice if I could replace the Sound Manager instead of just chuck it out in System 7.1.
