@zigzagjoe Hey, very interesting project! Did you ever tested it in a IIfx with a bunch of Digidesign nubus cards in it?
I haven't specifically tested on IIfx with digidesign cards, but conceptually it ought to work.
Production of these are on hold due to tariffs however.
Not entirely bad timing as I seem to be running into an issue with a minority of IIfx logic boards - the afflicted systems have a glitchy /AS signal which is causing cards to not work reliably. Interestingly, putting a pull down resistor on /AS
seems to help, but I haven't been able to quantify why as even putting my LA probe on the /AS signal is enough to also cause the issue to resolve.
There seems to be some precedent for this aside from IIfx generally being a finicky beast.
From MacWEEKV07N20:
"... a 33-MHz '040 card for the Mac llfx. The latter model, the TokaMac II FX 33, requires a slight alteration to the llfx motherboard...."
Also this post:
Many years ago I snagged a Tokamac IIfx PDS card (2004 ish). The software was vaporware for it so I contacted the original creator (Andrew W Donoho) and he sent me the correct drivers for it. He also told me the IIfx motherboards had defects from the factory with respect to bus mastering so you...
68kmla.org
The PAL in question is the one that also generates the /AS strobe for the IO bus/PDS so it's plausible there's an issue affecting both with the logic. I'd be curious if any of the SCSI Bolt (iifx PDS SCSI) card manuals exist and/or reference a similar problem.
