Centris 610 goes from LC040@20Mhz to full '040 and 25Mhz
MindWalker
A small success story...
I've had my Centris 610 for almost 20 years now. As time went on I wanted to experiment with A/UX which meant I upgraded the CPU from the stock LC040 to a full 040, the part I was able to source for that was a XC68040HRC25M, ie. a 25Mhz part. As the oscillator on the board (10Mhz, gets doubled to make the CPU clock) was the same, the new CPU ran at 20Mhz just like the old one. Would be nice to swap the oscillator to get full speed, but at the time SMD soldering was not something I wanted to experiment on.
About a year ago I mentioned this in a completely unrelated thread and @Phipli gave me some more ideas (thanks!). I also read this thread by @tecneeq. Then last week as I was preparing a component order to Mouser (due to some parts I couldn't get from my local supplier) I remembered the oscillator for the Centris. I couldn't find the same package as the original (ie. preferably this) from Mouser or elsewhere, and didn't want to order from china.
But then I kept searching Mouser with the specs I had from the aforementioned link and found this SMD oscillator at 12.5Mhz. Looking at the specs it seemed to check every box it needed: 12.5Mhz, CMOS/TTL levels and runs with 5V. It's much smaller than the original but even the pinout was the same and just needed a small pieces of wire to give it enough legs to reach the pads on the motherboard. I bought two (just in case I buchered the first one) and then waited to receive the parts. Bought my Centris out of storage, and finally today I received the bag of parts from Mouser and it was time to start working!
Here's the stock oscillator (front corner of the CPU):
Stock oscillator (top, upside down) and the new part being prepared:
New part soldered to the board (a bit ugly yes, but I just wanted to test it):
And it works! 😄 The machine has been running steadily, feels ever so slightly snappier and TattleTech shows that indeed the CPU speed went from 20Mhz to 25Mhz.
MacBench 4.0 (against the default PowerMac 6100/60) also shows a clear increase:
before: CPU score: 23%, FPU score: 8%
now: CPU score: 29%, FPU score: 10%
I am thinking about leaving this permantently in - can't see why I'd like to swap it back and I am not interested in overclocking - the 610 case is not that optimal for cooling to start with. A socket would be nice (and there is room) but I am not sure.
I've run the machine for half an hour with case open, MpegDec playing an online MP3 stream and my IR thermometer shows the CPU/heatsink is at about 40-45 degrees 'C, which sounds ok'ish I guess? I have a Nubus adapter with network card that sits over the CPU but there seems to be room - I'll see if I have any bigger heatsinks that would fit there. Just to be on the safe side.
Excellent work! It should be faster than a Quadra 700 now :)
Notice that there are four solder filled holes around the clock - the board is designed to take a through hole part instead of a SMD part if you want to. You could fit an 8 pin socket and plug a through hole clock into it.
MindWalker
Well yes, I didn't realize this until just today as I removed the stock oscillator... 😅
Had a quick peek at Mouser and couldn't find DIP 12.5Mhz part so at least I got the FULL 25Mhz for my effort! :geek:
Fizzbinn
Does your Centris 610 board have built-in Ethernet? If so I seem to recall there are issues with this type of clock upgrade due to the oscillator being shared between the CPU and Ethernet (for its 10MHz clock)
They don't - the empty footprint labelled "sonic" is where the ethernet chip would be.
It's ok though, even if there was a ethernet chip, you can solve the issues. Add an inductor, add a clock, move a resistor I think. It's documented online :)
Do you have an ethernet 20MHz machine?
Fizzbinn
I do but it has a Quadra 610 logic board in it! I couldn't get the original one (C 610 w/Ethernet) working. I did know there is a work around to take those boards to 25Mhz with working Ethernet just thought I'd bring it up in case it would be an issue and wasn't their radar :)
... I see the empty foot print in the 1st picture, didn't notice that, good detective work!
Fizzbinn
I think its doable but if you don't have another use for the PDS slot not sure it would make sense considering you have a working Ethernet solution.
But of course there is alway, "because it would be fun/cool for me to do" reason!
This is a bookmark I had that you may have already seen:
This is awesome, something I want to try to my own 610!
Also... I'm screaming in leaky battery right now from your first image! :D
