So what about the famous Apple ][ series?
magnusfalkirk
To answer your question on the "size" of the IIc it is 11 1/2 inches wide by 12 inches long by 2 1/4 inches high. So it should fit just about anywhere. You'll want to put the carry handle, on the rear, down so that it is propped up. That way you'll get air flow underneath to help keep it cool.
Dean
luddite
Host of RetroChallenge
Except in spaces smaller than 11.5 x 12 x 2.25"
:p
magnusfalkirk
:p
obviously, [:D] ]'> but that size makes it fairly easy to use in most places. And if you notice I did say "just about anywhere". [:)] ]'>
Dog Cow
No disk I/O will be possible without booting a DOS, but you can type in and run programs. Or, enter the monitor (CALL -151) and poke away at machine language.
Practically, you're correct about no disk access, but technically, no. You could type in enough machine language routines and essentially "type DOS into memory." 8-o
So, disks aren't "needed," but they are very, very useful.
To expand upon that, you need a disk to do anything useful. I don't believe that the IIc has a tape port. If it did, you could use a cassette in place of a disk to store your programs on one side, and music on the other. ;D
Charlieman
You have too much time, Dog Cow ;-) . However mortals can type in enough guff to enable a Super Serial card to receive data from a second computer, thus creating a boot disk.
Apostrophe
Apple IIc just arrived! (Minus the power supply; I'll have to contact the seller to ask about that)
It certainly looks yellow, and it's a bit dirty, but otherwise the keys seem great, etc. How do you open the case, though? If I can't run it just yet I can at least make sure all the parts are intact...
Just in case the sellers don't find a power supply, does anyone here have one that they might want to offer?
Thanks,
-Apostrophe
Dog Cow
I would never do that. I only got the idea because I read that Woz had to type in the BASIC interpreter into his Apple I every time. He did it so often, he had it memorized.
Apostrophe
Aargh! I got all the screws out, but I can't get the case off! It seems to be sticking near the spacebar, in the center front. Any good ways to get the case off?
-Apostrophe
david__schmidt
II2II
By carefully prying with a thin flat head screwdriver. The Apple IIc has plastic clips holding the cover together.
luddite
Did you try dropping it a few inches with the handle down? That usually pops it apart without leaving marks.
Apostrophe
I managed to get the case off (I did end up gouging the casing a tiny bit) but after a look at the interior I realized that opening it up again anytime soon won't be necessary.
This Apple IIc, despite having a dirty outside, has a pristine interior! Shiny logic board, no signs of leakage...and I even cleaned the casing and keyboard, so now the whole thing looks pristine! :)
So now I need a power supply so that I can see what this thing can do!
-Apostrophe
Scott Baret
Very interesting...I suppose if the voltage is correct it may work though.
I know this is somewhat off-topic, but since car batteries have been brought up, does anyone know of a good tutorial online that shows how to disconnect the cable from a car battery to reset a fluke check engine light?
