So, I bought a portable…
imactheknife
Ok, so got new battery today and popped it in. New 9 volt and she is golden, works great. So now i have to figure out how to get a system onto blue scsi. So when not in use, or while using it with new battery is it needing to be plugged in or only when battery needs a charge?
LaPorta
Lead acid batteries do not like to be discharged at all. They need to be kept up at all times if possible. You can either keep it continuously charged in the Portable, or as I do, I keep it on an automotive-style battery maintainer when I have the Portable in storage. One not-so-great thing about the Portable is that it pretty much draws as much in sleep as it does shut down: there’s no true “off”. The battery in mine will fully discharge in three days if not plugged in in some manner.
imactheknife
Ok, so good to keep plugged in with original power adaptor?
desertrout
Either that or remove the battery when you're not using it (and also remove the 9V). It really depends on how long you're keeping the thing on the shelf. I don't use mine a whole lot (once every few weeks), so I don't have a 9V in it, and I don't put the battery in it until I use it. I don't care if settings are lost, it's really the only reason to keep the batteries in. The 9V isn't even required, as it's merely there to power the system while you have the main battery out (like while swapping it). An SLA battery should be fine without a recharge for 4-5 months, so as long as you're using the Portable / recharging the battery a few times within that span of time, you're fine.
imactheknife
Ok, excellent, thanks for the info. Is system 6 the best for this? Only have 1 big meg of ram lol
LaPorta
I'd advocate for 6 with that. 7 will be a massive kludge with that paltry amount of RAM. Stick with 6. Any chance for you to find one of those RAM cards around?
imactheknife
No, it came with a modem. Will have to buy the ram card when more are in stock. This portable almost boots instantly with blue scsi, unreal.. have system 6 bare bones on it right now.
LaPorta
They are in stock, actually. Just buy the simple one. No need for the switch one since you have a non-backlit.
imactheknife
So I finally was able to install a “full” 6.0.8 system on this. I dont have a “brightness” slider but a contrast slider which does nothing. All other control panels seem good. Is it supposed to be contrast?
imactheknife
You're gonna need the Brightness Control Panel v1.3 IIRC. I'll try to find a link for it.
Edit: Portable control panel, sorry.
Link: https://macgui.com/downloads/?file_id=20773
Ok thanks!! So this is weird, i opened up the control panel on my iBook g3 clamshell and it actually controls the brightness lol.. i am using the ibook to transfer files to floppy.
LaPorta
This should work, however, that control panel looks different than the one I have on my Portable. Hold on and let me find the one I have.
LaPorta
This is the one from System 6.0.7. This should work...unless there is a hardware issue.
  • Portable.zip
imactheknife
Can someone send me a 4 gig or 2 gig blue SCSI sd card with the proper system folder lol.. this is driving me nuts...still nothing. says contrast. Will gladly pay for it
