Macintosh Portable Sad Mac 03001500 00001FFA
jlindsay26
Bought a Portable and when I got it it powered on and gave a Sad Mac code didn't write it down. I finished a recap last night also removed and solder back on three of the SRAM chips down in the lower right since the had a bit of corrosion. It boots but now if loops the startup chime if I reset the system. I'm getting a Sad Mac error 03001500 00001FFA came across a post whren it was a bad trace between ram chips and fixing that resolved the issues so I'll start there. Techkinght mentioned swapping RAM till you find the bad chip. Question does anyone know of a source for replacement ram chips or would I need another portable to scavenge ram chips from. Thanks in advance
jlindsay26
Good news cleaned the board more and touched up solder joints on the ram chips and everything is working now. In the interim I had bought another one for parts so I’m going to dive into that soon. I think more ram would be nice so that may be the next thing to do
alexGS
Interesting because I had a 1300 1FFA error code which I think was caused by the interrupt line being stuck as though the button was pushed. I reckon it’s right where those two small capacitors leak behind the buttons, it sets up some kind of via-corrosion problem.
I eventually managed to cut the faulty trace out of the circuit - isolating both ends - and the 1300 1FFA error finally went away - to be replaced immediately by a CD37 error (power manager handshake not present) :) sigh, rolls eyes… no-one said it would be easy, I guess
