"Unimplemented Trap" errors on Powerbook 100
Brooklyn
Hey all, I've got a recapped Powerbook 100. It works well but some games give an "Unimplemented Trap" type error. Specifically so far these 2 games don't work:
Sim Farm
Crystal Quest
I also tried on my backlit Portable and I get the same errors. So I assume it is not a hardware issue specific to my PB100? I am running System 7.1.
Same games work just fine on my Powerbook 180
LaPorta
Crystal Quest will work on either of those. I have played it on my Portable without issue (not to mention my SE), but I can't vouch for SimFarm. Are you sure you are not running some common extension between the two systems that may be causing an issue?
I am curious: what is the "2t" at the end of Crystal Quest?
Brooklyn
So I was able to get Crystal Quest to work by grabbing the latest version downloaded from Macintosh Repository.
Turns out SimFarm requires a 68020, oh well.
