twelvetone12
If you have a moment to test something ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I've been working on a module that adds an integrated AirTalk using the modem port of the 1xx (except the 190) series PowerBooks (see here). It works beautifully on my 100, but not on my 150.
What does not work? Well you need an extension to enable LocalTalk on the modem port, and that extension (from Apple) throws an error on the 150.
So I would need others that have one of the other powerbooks to try the extension and see if it runs. If it does, there is a chance my board can do AirTalk there and it is worthy to test the actual hardware. The only thing to do is to install the extension attached and then select the LocalTalk on the modem port in the Network control panel. If it does not die with an error, it should work![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If anybody has a moment to test this, I would be very grateful!
