Powerbook 100 IO Door?
twelvetone12
Is there anybody that has a powerbook 100 willing to help me get the measurements of the I/O door on the back? Mine is missing and I would like to put to good use a brand new 3d printer that is laying on my desk... I saw there is one for the PB 180 but I could not find it for the 100 (which is different), so I think drawing it should not be "too" difficult.
Thanks!
GRudolf94
Excuse the shoddy drawing and measurements, I don't have my calipers here, all I have is a dimly lit kitchen table and a ruler. The port cover appears to be symmetrical so keep that in mind. You can measure the powerbook itself and refine the dimensions, peg depth and placement, etc. Not sure if you'll want to replicate the original latch mechanism (which is just a slider with a catch and a plastic spring) but this should all get you close enough to just have to finish the details yourself. The sides where the pegs go are raised walls, the bottom part of the flap is about the same 2mm thickness as the rest.1688609732684.png
twelvetone12
Yes thanks both for the photos and measurements, maybe I can mock-up a simple version with a simpler latch design. I'm going to try to make a "template" with the measurements and see how it fits on the machine.
GRudolf94
The Apple latch is fairly simple, as far as these things go. That said, you could probably glue/melt a small magnet to the inside of the lid where it could catch, um, on the headphone jack maybe? And then just make a fingernail indent/hold at the top.
twelvetone12
Yes but it removes the fun of making it myself ;)
besides that is for the 180 and is different from the 100 (there are already stl models for the 180)
3lectr1cPPC
Yeah I’d never pay that much. They break so easily. All my early PowerBooks have the door missing. My 170 did actually come with one, but the latch was broken. Then I barely put the lightest force on it one time by mistake, it was basically no force at all. And it broke one of the tiny mounting pegs. The 100’s door seems better attached.
GRudolf94
100s seem stouter as a whole, at least when it comes to the plastics. My "daily" 180 is the least crumbly brick-series I've encountered yet, and feels nowhere near as solid as my 100s
