So, I bought a portable…
imactheknife
So i guess I will be an owner of a portable now lol.. with my powerbook 100 working, i got s good deal on a portable for $175 cdn. Will see what it is like when i get it… here is a snap
LaPorta
A good 12 years ago the same happened to mine, just stopped working. It was just caps, thankfully. If you need a comprehensive list, I can send you my cap list.
LaPorta
No 175 is a great buy if I’m good shape. Which reminds me, I have to open the one I snagged…
LaPorta
The above list does not include the axials behind the LCD (non-Backlit). For completeness' sake, I replaced these as well:
C11 - 220 µf, 10V Radial
C23 - 10 µf, 16V Radial
alexGS
Congratulations - I guess you’ll be making a new battery to turn it on with :)
I’m sure this is probably written elsewhere but…all three non-backlits that I’ve worked on have needed the Hybrid module replaced. Symptoms are: only powers on when the interrupt and reset buttons are fiddled with, hard drive doesn’t spin up or machine resets when use of the floppy drive is attempted, and won’t charge the (new) battery.
I suggest the reproduction hybrid module from user ‘supersvga’ on eBay (and in this group too I think) :) I fitted one and everything worked straightaway - wished I’d replaced it first, hence this post 😊 I was really impressed by the quality of the item.
moldy
I would recommend replacing the hybrid as well, even as a preventive measure. Bad hybrid might send >6V to the AD converter of the Power Manager chip, which fries it (and the only source is another Portable or PB100). Based on my M5120 with two units, I suspect hybrid modules are actually the major cause of dead PMGR ICs.
When fixing my M5120, I've tried to wash the hybrid with IPA multiple times to get rid of the cap goo, but it never worked properly and did some funky thinks with voltage rails. In retrospect it was an unnecessary risk given the reproductions are available.
3lectr1cPPC
Did your unit have any cap leakage, or was the board in pretty good shape when you got it? To my understanding, the Hybrid's on-ceramic resistors get corroded easily by the caps next to them and cease to output the correct resistance, causing the module to fail. If I'm correct here, just about any hybrid that hasn't been exposed to cap juice should still be fine, in theory.
Of course now, the number of systems that fit this criteria is few.
LaPorta
Oddly it wasn’t as great as you’d think. I was lucky it didn’t get burnt out by the PB1xx power adapter is used before it was common knowledge that that was very, very bad. It eventually stopped working due to cap leakage. When I started replacing the caps, I ran into issues with screen issues and sound glitches. Even today there is the most faint background hiss at the highest volume, due I think to some microscopic residual cap goo inside the board. Techknight helped me work through the worst of it. Here are the threads from back when:
