So, I bought a portable…
LaPorta
I was just basing this on your video showing the slider doing nothing. The above is correct, there is no “brightness” adjustment on the Portable…just contrast. That is all. The fact that your contrast slider doesn’t do anything…I thought that was your issue and thought that newer control panel might not be working properly. No idea why your contrast slider, with the correct control panel I sent you, doesn’t adjust contrast.
desertrout
@imactheknife On mine it's very noticeable, the lowest end of the slider makes the display quite faint. FWIW I did see a difference in your video, but it was very minor - certainly should be more.
imactheknife
Interesting, well i wish i knew if i had proper version of 6.0.7 on it, or of there is a more specific version for portable?? When i installed a chose under customization to do portable etc. i wish i had more memory lol.. maybe system 7 would be better??
desertrout
I have doubts 7 would make a difference, and likely will drag without enough RAM. I'm using 6.0.8, seems good. This might merit a look at some docs to see how the contrast is being controlled... I'm not sure what the control panel is doing exactly, but it might be discoverable looking at tech notes and the schematics.
imactheknife
Would it be something on logic or lcd? It is recApped etc and working excellent otherwise
desertrout
I honestly don't know - I'm not familiar with the LCD circuitry. There *are* caps on the panel but they're not so prone to leakage as on the 1xx PBs afaik. Others have recapped their Portable screens, but I'm not sure if it was to address contrast issues. I wish I could provide more certainty here. I can take a look at some docs later and see if anything becomes apparent.
desertrout
So, the dev notes (https://cdn.preterhuman.net/texts/computing/apple_hardware_devnotes/Portable.pdf) describe the contrast control as a pwm signal from the Power Manager which is run through an rc network.
Here's the network in question:
I'd do an inspection around those components (which are over by the right-side keyboard connector), maybe some testing and extra cleaning. Possible there's some lingering electrolyte from C14 and C116 mucking things up.
LaPorta
I do have two (to my knowledge) 1 MB expansion cards that I’m not using since I have the Maceffects 8 MB board.
