Hi all,
I read many times on the internet that you can swap the passive matrix LCD in the 190cs with an active matrix LCD from a 5300c.
Well I was lucky enough to find a new old stock LCD screen for a 5300c. I fitted it inside my 190cs bezel no problem. But the machine only shows white, I can hear it loading the OS in the background etc but just white light on the display.
I'm not sure if it is to do with the fact that I replaced the screen alone, not the entire screen assembly like some others may have done.
Any thoughts? Thanks
