Questions about 5xx batteries
3lectr1cPPC
The PB 540 I just got in from eBay came with two batteries that are both detected by the system and pass all tests in EMMpathy/Lind/Apple's utilities, so they are certainly good candidates to rebuild. While they do hold enough charge to keep the system in sleep mode unplugged, they will not power the laptop itself while it's on. When I do eventually get around to rebuilding them, I'd like to know a few things:
1. What cells should I use? I'd like to get like-for-like replacements to the original cells if possible, not hacking up a pre-built pack and fitting it in like some have done.
2. How do I get the casing open with the least damage?
3. Is there anything that I need to do, like keeping the EMM powered while I install the new cells?
Here’s a picture of the packs. No visible external corrosion!
aladds
I re-celled one in perhaps 2004 and I used tabbed AA cells, but they're certainly not the same as the originals. Pretty close in size, though, and usually higher capacity. They probably need doing again now actually.
As for opening the case nicely... the issue is that ridge in the middle. It's ultrasonically welded along that ridge as well as the outside, so it's very difficult to break that without warping the pack some. Your best bet would probably be to get it apart however you have to, then shave down the case some after and use epoxy and perhaps a jig to get it back to the "normal" shape.
As for your third question, the Apple Intelligent Battery Recondition software or EMMPathy (Actually lots of useful tools here, including the Apple tool) are what you need to reset the intelligent module. No need to keep it powered. If it doesn't work first time run the utility over and over until it does. The Apple utility asks for the serial number and this is an attempt to match the controller to the cells. I remember sometimes you had to try one setting and then the other and eventually the powerbook would recognise them.
3lectr1cPPC
Thanks for the reply! A couple more questions:
1. Tabbed AAs seem like a good way to go then. I've never recelled a battery before, about all I know is to get tabbed cells to avoid soldering directly to them. My main concern is figuring out how the whole thing is wired up, but assuming the insides are in good shape (which they seem to be from the fact that both are currently recognized) I could probably just study that to get an idea of things.
Edit: Found these on Amazon: https://www.amazon.com/Combo-Tenerg...ocphy=9015321&hvtargid=pla-570918665741&psc=1
(side note - I love how the Amazon page advertises these are perfect for rebuilding dead packs. right to repair FTW!)
2. What ridge are you referring to? Is it this: 6BFDDE47-C64C-416F-BBE0-7C88132A8914.jpeg
3. I think the fact that both packs are already recognized and charged is a good sign that I won't have to fight too much with the EMM, but we'll have to see. It will probably be a few months (or more) before I get around to this, just getting info now. I've already run EMMpathy, Lind BU, and Apple's software to try to revive the current cells, with no real luck, but the EMM tests good on both packs.
Finally, a forth question. What voltage is the pack supposed to be? Pack #1 charges to 9 volts and Pack #2 charges to 7.5. Which is correct?
aladds
1. Yes they look good.
2. Should have clarified - I suppose it's more of a groove. The bit you're showing in that picture is actually a clip-on cover and you can pop it off with a spudger. I'd recommend you do that first, actually. The EMM PCB is underneath it. You essentially have to break the ultrasonic welds around the batteries which includes the bit behind that PCB.
3. Very true. I've never had a "factory working" 500 series battery so I can't speak for what you'll encounter with a working one.
4. There are 8 1.2v cells. If you look up NiMH charge & discharge curves you'll see that "full" is actually close to 1.45v per cell once the charger has settled, and "empty" is closer to 1.15v, so your 7.5v battery is in pretty bad shape (pretty much fully dead) and your 9v battery is just below "completely empty" but probably enough to register on the battery meter. NiMH cells are interesting in that you know when they're fully when they get warm, so batteries have temperature sensors inside to detect this.
3lectr1cPPC
Very interesting, I don't know much about how NiMH batteries work beyond the memory effect so this is all news to me! I guess that's why they're not running the computer! As for the heat factor - that's very interesting as I do have one single working NiMH laptop pack, the pack for my ThinkPad i1260. I've had some pretty bad calibration issues with it that seem to keep returning despite me recalibrating it twice. When it's properly calibrated, it will run the laptop for an hour and 20 minutes, and it gets very warm while charging. When it's having issues, it doesn't warm up and won't run the computer for even a second, although the lights do flash briefly when I attempt to power it on.
Aha, that's what you meant. If that's the case, I'll probably try to get access to a small vice to use, as I don't have one. Maybe I should get one though, as I've got some dead PowerBook chargers I need to crack open to recap. Brute forcing it with a screwdriver would probably work but it would also completely destroy the fragile case.
Edit: My spudger isn't fitting into the groove over the EMM cover. Where are the clips located and where should I try to leverage it from?
3lectr1cPPC
Goodness me, I have no idea what I meant to say but it wasn’t glass. No idea how that autocorrect even happened!
Anyways, I got the cover off both batteries without cracking anything, 2 happy looking EMM boards!
How should I go about opening the rest of the pack then? I’ll be at a local place this Friday that should have a vice, but the ultrasonic welds go behind the EMM board.
jmacz
I just opened up a pack from a 540c. It was straightforward to get open using an X-acto knife and just taking multiple passes and cutting along the seems. This particular pack was in good shape. There's some power as the batteries were deteriorating but the PCB, chips, ribbon cables are all intact with no damage.
I'm going to replace with a 2200mah 9.6V NIMH AA pre-built RC car battery pack.
But before I do, I was looking at the existing cells:
The two red arrows above, are these fuses or? They are inline between the first 6 cells and the remaining 2 cells.
And for the thermal sensors (blue), what have people used to remount them on the batteries? I don't think the existing clear gel on them is hot glue.. but some type of silicon or something?
3lectr1cPPC
I *think* the red arrows are thermal fuses. I have a different revision though so mine look different. As for the blue guys, not sure really.
3lectr1cPPC
3400 batteries can’t with conventional equipment. The BMS locks down when the old cells are disconnected and they won’t take a charge. I’ll bet you can reset this with specialized equipment (Chansbattery.ca can probably do it I’ll bet).
beachycove
There is an old trick, which may be relevant as your batteries seem to be in pretty good nick.
Freeze your batteries overnight. Return to room temperature, recharge, and cycle a few times from full to absolutely empty using Battery Recondition or a similar (NiMH) battery utility of the period. You might well get a good 90 mins charge from the batteries you have.
Freezing is said to break up nasty crystals that have formed over time in your cells.
This won’t work if your cells are beyond fixing, but it can transform a good but otherwise tired PowerBook 540 battery.
3lectr1cPPC
That may very well work for some batteries, but at this point from what I’ve seen at least, every pack I’ve opened has at least some leaking cells. If they’ve started to leak then at that point I highly doubt any pack would hole enough juice to start a laptop. All 3 of my 1400 batteries had also started to leak to some degree, only a few of the cells, but that’s still enough. No harm in trying it though! I actually have to do this again to an aftermarket 100 series battery I have that still works.
imactheknife
can powerbook 100’s be done? Sorry so many questions lol.. have two nice ones. Also, have two battery chargers that hold two 100 series batteries too that would be cool to use.
3lectr1cPPC
The freezer trick is supposed to work on NiCad and NiMH, and the 100’s batt is Lead Acid so no. Although I saw a thread that at least as recently as 2016, people were able to revive original 100 batteries by resulfating them. Although now the better option would be to pick up one of the new lithium converted batteries off eBay. I still need to do that at some point…
jmacz
I put a pack together using 2200mah NIMH prebuilt (RC pack). It’s showing 10.6V. I connected it to the EMM board and I’m seeing continuity from the board to all 4 external connector pads. I also see the 10.6V across connector 1 and 4 which is good. But my 540c isn’t seeing the battery at all. Using Lind, Intelligent Battery Recondition, EMMpathy all can’t see the battery. Given the voltage is there, my guess is the 540c isn’t seeing what it expects to see from EMM board on connectors 2 and 3, which probably means something is wrong with it. I don’t have a second battery to test either so looks like I’ll have to try and debug this.
jmacz
What’s the approximate selling price for a dead PB 500 series battery? Haven’t seen one listed here or on eBay for quite some time. Trying to decide if it’s just better to get one with a trashed 500 series laptop.
GRudolf94
Honestly we should just look at understanding how these stupid things work and making new ones. I have an EMM torn apart from a mangled pack that I intend on reverse-engineering, allowed enough free time, and dumping the MCU on. I know zero HC05/HC11 but I'm sure I can get help with that part.
