I picked up this 15V 1A charger. It's for charging those portable battery packs for jump starting cars.
I again figured the battery voltage is 9.6V and while charging, I remember only seeing it get to 12V or so. I believe as long as the current is good and the voltage is higher than the battery, it should work to charge the battery.
I received it today and measured the voltage, it's putting out 14.99V. So I took a shot, disassembled the charger (it's small), and wired it up as my VBATT. It's working thus far. It's not cutting out and EMMpathy shows it's delivering about 1.02A to the battery during the charging process. My battery is charging. The battery was down at about 60% according to EMMpathy. It's currently at 67% after charging for a little bit. I'm going to let it fully charge and watch the temperature to see if there's any change charging at 1A vs 2A.
Also received the caps for my stock charger. Will recap the stock one this weekend and see if that one works and try the same thing with that stock charger as well.
Lastly, I received the new NIMH size "A" cells today. I test fit them into the case and all 8 of them fit - it's a super tight fit. I've got really thin battery tabs so will try spot welding these cells together this weekend and check the results of that to see if there's any material difference in temperature, capacity, etc.
