emendelson
The PowerBook G4 Titanium A1025 that I bought has its hard disk loose in the drive bay, and I'd like to attach it with the screws that are supposed to attach it on the left side to the battery bay. Everyone says that these are T8 Torx screws, but no one says anything about the length of the screws, as far as I can tell. I have the circular bumpers that fit into the openings in the bay and am missing only the screws. Any advice would be gratefully received.
