beachycove
If you were really to try them (they would not fit, BTW, and the voltages are different), the Lithiums would eventually — no, inevitably — catch fire and/or explode, and either burn your house down, or if you were unfortunate enough to be using the machine when it happened, hurt you big time — the gases released from the cells could very well blind you. That's besides the serious toxins breathed in/ handled in cleanup/ lived with for the duration.
I reckon that's a pretty good set of reasons not to tinker with the unknown in this case, even if the result of the tinkering did by some miracle happen one winter Saturday to give you a twelve hour charge. Besides, YOU CAN RECELL A DUO BATTERY with tabbed 4/5 AA NiMh cells, and the charge will sustain the machine for longer than the machine is likely to sustain an interest. That the result will not be everything you want in dreaming the dream is just ... life. Ho hum.
As for a hack/ redesign of the charging circuitry and System software (which seems to be involved — the moves from either Type I to Type II, or from there to Type III batteries, required a System update, precisely so that the benefit of the move would be felt), maybe it can be done. At the moment, however, it might be wiser simply to observe that tabbed NiMh cells themselves are dangerous enough, and not at all like the button cells in the supermarket, as handling them the wrong way can cause steel to glow red-hot within a couple of seconds — if in your pocket, they can literally burn a hole in your leg.
So you really, really do need to be careful if you go there, and I for one would not want to tinker too much with software or anything else where these things are concerned without an engineering background. 'Tis not a ResEdit hack. At most, try your best simply to replicate what is in the machine already.
