alectrona2988
yeah so its likely active matrix, my bad. that cable on ebay unfortunately won't work.
Awesome. Thank you for checking.I'm pretty sure that isn't a Sharp. There's a small, small chance that it's the rare Hosiden panel, but it's probably a Toshiba.
I have similar issues with my only PB 180c now. So the next days/weeks are reserved for these PBs and some more. :-(Cable or screen issue. Try reseating everything inside, they’re pretty prone to connection issues.
Yes is sharp.I'm pretty sure that isn't a Sharp. There's a small, small chance that it's the rare Hosiden panel, but it's probably a Toshiba.
Rats. I guess my ID skills aren’t as good as I thought they were! I’m glad you got it sorted regardless - I’d try reseating that LB to display cable if you haven’t already, there’s a chance it’s loose at the logic board side. Either that, or it’s just damaged.Yes is sharp.
Here is the update on this. I removed the vinegar syndrome display and plugged to display with missing line and it works. The display is as sharp (no pun indented) as it can be. The flickering issue is also gone. So i think the problem is with the display connector from logic board to the display.
Now i have one fully working 540c and one working headless 540c.
Hahaha yup. Now don’t go to Vegas to play blackjack lol. They use cards from same deckRats. I guess my ID skills aren’t as good as I thought they were! I’m glad you got it sorted regardless - I’d try reseating that LB to display cable if you haven’t already, there’s a chance it’s loose at the logic board side. Either that, or it’s just damaged.
