Johnnya101
Mission success in transplanting a 160 display cable to my 140!
Screen is super duper bright and contrast and brightness work... well... like new! Screen is crisp and clean for the most part. But of course, like always, theres an issue. The bottom half of the screen has lines on it, but ONLY the bottom half! Bad screen, logic board, cable...? Cable has good continuity so I would hope its not that. Hope this is a known and easy fix? Also some ghosting on the top left. Looks like what would happen on an unrecapped LCD.
ALL CAPS REPLACED on LCD and inverter (You can tell. SUPER bright screen! ). RECAPPED PSU!
Also I noticed that after not using the speaker for a minute, and if I go to the sound control panel and change the volume, theres a loud click right before it plays the sound. I also noticed just messing around in the OS there is a click once in a while. ??? Is it just warming up after decades of rest? No battery installed.
