PowerBook 140 restoration
DW1992
Hi Everyone,
A friend who knows I enjoy restoring vintage machines recently gave me her dead PowerBook 140 that had been stored and forgotten about in the back of her closet for decades.
It is in excellent cosmetic condition for a 33 year old laptop!
The fun begins...
I could hear tiny bits of plastic rolling around inside, so I suspected that the screen hinge mounting plastic had crumbled into dust.
Unfortunately I was right. lol
But fortuntly, I have another friend who 3D printed a new hinge mount that I epoxyed to the rear screen case.
Sunk the brass bushings into the new 3D printed hinge using the soldering iron's heat and voila, screen mount fixed! :)
The battery was fused inside due to corrosion.
Managed to remove it and the damage to the power/charging connector was done. That whole piece had to be removed from the logicboard.
Removed everything, washed all the plastic casing.
The screen was dead, common and not unexpected due to the bad leaky caps on the LCD.
A quick order from Mouser fixed the LCD.
I also changed out the two inverter caps and the single cap on the trackpad (no signs of leakage on the trackpad, but the case is open, so why not?). :)
She had 4MB of memory installed (2MB on board, 2MB expansion), pretty awesome when it was new in 1991, but I picked up a 6MB memory module, just because it's cool and purple... :) giving it the maximum of 8MB.
The end cap for the battery came off perfectly, so the battery compartment is still able to be enclosed for aesthetics.
The hard drive clicks, but I intend to replace it with a BlueSCSI / WiFi Pico anyways (once they are back in stock).
Question...
Has anyone had luck using a 3rd party generic power supply?
I've been powering it with my bench supply set to 7.5vDC drawing ~1.5 to 1.8A.
She couldn't find the original Apple power supply, it's probably long gone. So I'm looking to just use a generic for the time being.
It won't be for charging the old Ni-MH battery as the battery and connector have been removed. It's just for powering the machine.
Down the road, perhaps a Li-on back could be worked on for it, but not in my list O' things to do anytime soon...
Attached is a pic of the machine (without it's front bezel) running after cleanup, recap and hinge mount replacement. :)
Cheers everyone!
Aaron / DW
Dark Systems BBS
Powerbook27364
Question...
I was able to buy a modern generic one off of eBay. It was labelled as working on this series of laptops and it was 7.5v 2a. Worked well with my 140/145B/170 for several months and I only stopped using it once I recapped my original power supply.
Someone was working on a lithium solution, but it never got to a finished state. This is something I really want to figure out how to do but i just don't have the knowledge unfortunately. https://68kmla.org/bb/index.php?threads/pb-1-4-8-0-5-c-li-ion-battery.37075/
Batteries can be rebuilt using 10 x 17500 style Ni-MH cells (though this will usually require a spot welder), or using a pre built pack such as this one, https://www.batteryspace.com/NiMH-Battery-Pack-6V-4500mAh-27Whm-5S/S-MH-4/3AF4500.aspx
Using the pre built pack has good capacity and only requires soldering the terminals. I plan to use this to build a second battery.
Eventually, I plan to do the LED backlight mod to my 145B and make it a lithium pack once I have the knowledge of how. You can also put the cpu card from a PB 170, which runs at 25MHz and has the FPU into the 140 if you want a faster experience, which is what I have done to mine since my 170 has tunnel vision and the display has issues.
DW1992
Cheers Powerbook27364,
I appreciate the links to the battery articles!
I ended up buying a general multi-select voltage power supply (set it to 7.5vDC @ 3A max) on Amazon.
Works no problem with my PB140.
I'll probably use it until I can pick up a real Apple supply and fix that up someday.
I love ZuluSCSI, super slick.
I have the RP2040 in my SE/30 and Colour Classic, but I'm really hoping to put a BlueSCSI 2 with the WiFi enabled Pico in the PowerBook for obvious WiFi / network reasons. :)
Trick is, the BS2.0 PowerBook edition seems to be sold out for now. Fingers crossed, keep checking BlueSCSI.ca for stock updates.
Thanks again!
Take care
Aaron/DW
Dark Systems BBS
Powerbook27364
No problem. I really need to get one of those bench power supplies if I keep getting more computers. I would love WiFi on my PowerBooks but I already have the original BlueSCSI in the two laptops I use most (145B and 280). Maybe I will pick one up for my newly acquired 540c since it has a mechanical drive currently but I have no clue if WiFi on a 68k machine is any good. I hope they come back in stock soon.
DW1992
My 68K compact machines have PDS network cards.
I use the connection mostly for transferring files from my Synology NAS via FTP (easier than popping out the SD card from the ZuluSCSI). :)
I have our printer (an Oki laser) shared with them. Works great as a LaserWriter LPR printer. :)
SSHeven is fun to play with. But anything less then the SE/30 starts to not be as fun. lol
If you're into BBSing, lots of Telnet BBSes to explore. Some are even Apple centric.
The CC Mystic is fast enough to stream internet radio to it's little internal speaker. :)
Aaron/DW
Dark Systems BBS
Powerbook27364
I have just been using good old floppies for most of my file transfer. the bigger files get loaded onto an emulator and copied to my external BlueSCSI image for my Color Classic. The PowerBooks have to use serial form the CC for large files. It certainly isn’t ideal, but is the only way I have right now. I don’t have a mystic so I was planning on doing a PDS processor upgrade to the CC, but that stops me from having Ethernet. All of my 68k macs are 25MHz 68030 or slower apart from my tunnel vision duo 280 and 540c that I haven’t used yet, so I don’t know if I will have any luck streaming audio or doing more intensive tasks.
DW1992
Hi Beachycove.
I'm using MpegDEC for the MP3 stream.
I've attached a video of my CC Mystic loading MpegDEC, then playing the 64K/sec from Nectarine, Demoscene Radio.
It's a 64K/sec stream, but on the internal speaker it sounds just fine. :)
The file I drag into the player is a text file with the address of the stream in it.
Here's a website with more info about the process:
  • FullSizeRender.MOV
    3.7 MB
DW1992
And here she is, all put back together and running System 7.5.5
8MB of RAM, using a 6MB funky purple memory expansion module
Hinge support completely replaced with 3D printed support
Dead HDD replaced with a BlueSCSI v2
DaynaPort Ethernet (WiFi) courtesy of the BlueSCSI v2 (FTP for files and also prints great to my networked Oki laser)
Recapped screen, mouse and inverter
Power supply is an aftermarket
Original Ni-MH battery removed (totally corroded) but case cap saved
3.5" floppy reads/writes perfectly
Nice machine to type on using ClarisWorks. :)
