jonpurdy
So this is a weird issue that's taken me many months to diagnose.
To summarize:
So, are there any ideas about what to try next? It is possible that both SW2200s have the same issue (they test print but can't receive data from the Mac). I don't have a second vintage Mac here to test and won't be buying one (no space and have enough machines back in Toronto). But I'm happy to have spares of everything; I would've ordered these even if I didn't have this issue.
- Picked up PowerBook 2400c from @JRL in February and it works really well aside from this issue; absolutely my favourite Mac ever despite the tiny keyboard.
- Ordered a StyleWriter 2200 shortly after that in almost mint condition from Japan, finally received it in late May.
- SW2200 boots up, prints test page just fine, paper occasionally jams but it does work. Except that it doesn't receive print jobs from the PB2400 (2400 just says it couldn't communicate with the printer).
- Recapped SW2200, same issue.
- Ordered a second (cheap) SW2200 around July; same issue. Works fine with test printing but PB2400 can't print to it.
- Checked the miniDIN 8-pin cable and each pin has continuity.
- PB2400 has the correct extensions (tried both the original 2200 and later 2500 extensions). Tried 7.6.1 and 8.1.
- Got lucky and found a DB9 Serial Port Plug (Apple #077-8129) to run the MacTest Pro serial loopback; failed!
- Ordered a second logic board and IO board for PB2400. All combinations of original + second boards don't print to either printer and fail the serial loopback test.
- However, randomly figured I could the PB2400 into my MBP using my USB-Serial adaptor and the mini-DIN to DB9 cable. Tried this and I was able to send text across the wire with ZTerm! Major breakthrough! (Even tried this out with SheepShaver and pointing the modem port to my USB serial device and it works great!)
- Edit: when I try to print with PB2400 connected through USB-serial on MBP listening in CoolTerm, I do see a few hex characters show up, so the 2400 is definitely trying to do something.
To summarize:
- PB2400 (original parts) + SW-2200 A = can't print
- PB2400 (original parts) + SW-2200 B = can't print
- PB2400 (newer parts) + SW-2200 A = can't print
- PB2400 (newer parts) + SW-2200 B = can't print
- PB2400 (original parts) + serial loopback test = fail
- PB2400 (newer parts) + serial loopback test = fail
- PB2400 (newer parts) + ZTerm to MBP = success
- (didn't test original parts + ZTerm yet)
