JustG
I finally worked up the courage to start desoldering the bad caps on the LC logic board I found at a local electronics recycler.
About an hour later, not a single pad lifted. The board is now drying after being washed in some very diluted soapy water.
This LC didn't power on so I'm going to attack the power supply next, is there a pinout so I can test that the supply is outputting the correct voltages after I replace the capacitors?
Also, I noticed the IC at UC9 which I believe is the audio amplifier has shorted or burned up. Would it be safe to attempt to power up the computer without replacing this component? I did a decent job pulling the bad capacitors (my first time doing surface mount work) but I'm a little nervous about trying anything with more than two solder points.
