Mu0n
I wanted to do this for last winter, but I got sidetracked. Right now, I haven't even completed the proof-of-concept, but my goals are:
phase 1:
-Have a nice little demo program with a winter snowfall theme in the same vein as the famous C64 christmas demo, possibly with music out of the 4-tone synth.
-Specifically targetting a Mac Plus so that I force myself to optimize the graphics for all macs that I care about
phase 2:
-Provide a scenery (houses, cottages, trees) so that the snow accumulates over these uneven surfaces instead of an empty flat ground
-Let users provide their own curated image (force a white or black background so that the program detects the accumulation polygonal line and let snow accrue there)
phase 3:
-Let users edit snow accumulation polygonal lines
Here's what I have so far, running in mini-vMac at 8x speed. I'm not happy with the slowness on a real Mac Plus. It works as a slow snowfall, but I can't believe I can't put it faster than this:
I'm pre-generating the snowflakes as a char (8-bit) array of 64 characters width (which manages exactly 512 pixels, 1 bit per pixel, same as the compact mac resolution) and 400 lines height (so that the visual repetition of the snowflakes isn't so obvious and memory usage is kept on the downlow).
Instead of using a purely random function, the snowflakes are pulled from a hard coded array of character possibilities, such as 0x01, 0x02, 0x20, 0x80 and counterweighted with with lots of padding 0x00's so that I can control the density of snowflakes until it becomes visually appealing instead of a trash grayish average random.
Algorithms for displaying and scrolling the snow:
Algorithm #1: Copy into an offscreen buffer using Longs with an offset, then copy back the whole buffer into screen memory
-Lock the handle to snow data buffer
-Generate a new line of snow data in an offscreen buffer
-Get a long pointer to the start of the screen buffer
-Get a long pointer to a few lines after the start of the offscreen buffer (this is adjustable according to the number of skipped lines you want to increase the sensation of fall speed)
-Copy the screen content to the offscreen buffer, stop when you reach the last detected snow line on the ground using 2 nested for loops (every line between the top of the screen to the snow line, all 16 longs (32-bit each))
-The ground line gets a special treatment, its content is updated with a bitwise OR to *ACCUMULATE* snow on top of what it already had
-Count the number of pixels in the ground line, if it's above a threshold, make it empty and bump up the line 1 pixel above
-Copy back the offscreen to the screen using nested for loops
-Unlock the handle to snow data buffer
How many times can it be done between vertical blankings (VBL)? TO BE DETERMINED (will post later)
If not tied to VBL, how many ticks between them? TO BE DETERMINED (will post later)
Algorithm #2: Use ScrollRect directly on screen and draw a new top line
-Use ScrollRect on the main window pointer to the portRect and scroll it a number of lines (adjustable in code)
-Generate the new top line directly on the screen memory
-Currently has no management of the ground snow line
-Will crash/exit out once the scrolling reaches a threshold since it scrolls an important Rect related to the screen
How many times can it be done between vertical blankings? TO BE DETERMINED (will post later)
Algorithm #3: Use OffsetRect on screen memory, use CopyBits to an offscreen buffer, then copybits back to screen memory
-Use OffsetRect on a copy of the Rect assigned to the main window ptr
-Use CopyBits from screen to offscreen and using the offset rect to create a displacement
-Generate the new top line on the offscreen buffer
-Use CopyBits from offscreen back to screen memory
Algorithm #4: Roughly similar as #3, but using BlockMove instead of CopyBits.
-Currently not working as it should
phase 1:
phase 2:
phase 3:
