Computer arrived yesterday. The computer works, though I decided to change the OS on it. I appreciate that the seller took the time to do a clean install of OS 9.1, but I think this OS is overkill on this machine. I decided to downgrade it to System 7.5.5. It starts up a bit quicker now, it's not a night and day difference but it's pretty significant. Even better though, I now have more free disk space. The HDD is 800 MB and OS 9 took about half of that. With System 7, I now have about 600 MB free. I love the screen on this computer. Much better than the passive matrix one on my Powerbook G3 Main Street. I had the two laptops side by side because I needed to make System 7 floppies and the difference between the two screens is night and day.
The floppy drive works well with both 1.4 MB and 800k disks, so I might use the 5300c as my bridge Mac instead of the PB G3. I'm thinking about getting a CF to PCMCIA adapter and using the CF card to transfer files between my PC and my Macs. In the pretty likely event that I run out of space on this HDD, I might buy a second CF card for use as a second HDD. I think System 7.5.5 can read and write CF cards right? Or do I need OS 8 for that?
As far as programs go, it will be interesting to see what will run on here. Wolf 3D runs fine on here, but when I tried to install Word 5.1, the installer froze halfway through. I have Word 6.0.1 coming in the mail though, so there's that.
I guess I should get a SCSI CD-ROM too at some point. Should I be looking for an Apple CD-ROM drive or would a third-party drive work?
