coius
Some of you in the #68kmla went through this with me, but wanted to spread the word. I had a client come to me with wanting me to reset the Password on his PowerBook G4 1.67Ghz 17" w/ 1GB RAM (long story...) and when I tried to, it wouldn't reset (Encrypted)
So, the next best thing... Reinstall. So we got out the install discs, only to find a few minutes into the install KERNEL PANIC!
Thinking it might be a hardware problem (Good guess I guess...) I popped in TechTool Pro. and low and behold, BAD HDD Sectors! Well.. This means only one thing. Harddrive replacement!! One thing I hate out of ANY laptops out there, are APPLE LAPTOPS. Well... this one shocked me. using iFixit (or PBFixit, don't remember...) I went through 3 major steps (not really, just a bunch of screws) and I was in to the drive. WOW! that was *really* easy. Took me 5 minutes max to go into it and replace the drive with another drive (100GB replaced by another 100GB HDD). I now have 10.5.1 installed and almost ready. This was an overnight job and made $175 with the harddrive being install. Not bad for like 3 Hours of work... Not bad at all...
So, if anyone is thinking about going into your 17" PowerBook 1.5/1.67Ghz, it is REALLY easy. almost as good as going into a powerbook G3 Pismo. Simple inandout really quick. Just wanted to give the heads up!
