Caps! -- (Supplies For Beginners) What do you need?
uniserver
Ah, yes some important details I forgot to mention.
When I preform the twist off method, I make sure to apply firm downward force as well as twist.
my downward pressure i am sure helps secure the pad reasonably.
Also you should have a NON slip ESD safe surface to work on.
Its hard to work on a Logic board with it slipping all over the formica/glass on your desk.
Sorry for leaving out these details.
uniserver
well for 13 + tx + shipping..
You might be better off getting this temperature controlled soldering iron for $20.00
http://www.microcenter.com/product/391342/Low-Cost_Soldering_Station
It does work good for lead free, couple things though.
- Make sure your tip is on there good n tight!
- Make sure your tip is tinned and clean.
- Turn the dial all the way up. and give it about 60 full seconds to heat up.
- if you are still having issues with your lead free joint, then melt some 60/40 on it first.
then it will all melt in just fine.
NJRoadfan
So basically, I'm not wrong when I don't use flux when I recap boards?
Chances are your solder is "rosin core" and has flux in it already. Otherwise the joints you create usually won't stick when they aren't cleaned with flux.
uniserver
i get alot of trashed out boards needing re-caps, - failed re-caps, I use flux alot.
Flux is also great used with solder wick when your trying to scrub off corrosion and trace rot.
i find that if you keep your tip really clean. And if your pads super clean…
and if you are not trying to re-install someones solder blobed up tantalums.
The 60/40 rosin core solder provides a sufficient amount of flux.
mcdermd
Typically, I do a LOT of cleaning throughout the process with alcohol and swabs, solder wick and silver bearing solder.
