Sounds like a great candidate for having a Duo Modem Connector's Thru-Holes on the opposite side pf the PCB!Once this project is done and over with, i am going to make a replacement modem for the PB1XX series
Beautiful Boards, Baby!
mode>
SCSI controller debug system
Hardware: V2.0, Firmware: V1.0 (Build: 2006-06-24T13:27:21 UTC)
Init target:
Create UNIT ATTENTION condition for LUN 0 (Reset)
Enable interrupts ... OK
Target POST:
SRAM test ... OK
POST complete
Init PCMCIA card services:
PCMCIA card found
Init PIA:
Read our SCSI ID from jumper block ... 2
Configure PIA for target mode ...
Cannot configure PIA
Fatal error (E3): PIA failure
I will die now
Hardware: V2.0, Firmware: V1.0 (Build: 2011-04-24T14:40:29 UTC)
Init target:
Target POST:
SRAM test ... OK
POST complete
[PCMCIA CS] Initialize card services
[PCMCIA SS] Initialize socket
[PCMCIA SS] Set address: 0x03FFFFFF
[PCMCIA SS] Set address: 0x00000000
[PCMCIA SS] Set latched control lines: 0x20
[PCMCIA SS] Read socket status: 0x01
[PCMCIA CS] Card status: CP
PCMCIA card found
Init PIA:
[PIA] Init PIA
[PIA] Get status ...
[PIA] Read STATUS register: (0x04) OK
[PIA] Check status: Ready
[PIA] Send CONFIGURE command to PIA ...
[PIA] Write CONTROL register: (0x01) OK
[PIA] Write DATA register: (0x02) OK
[PIA] Write DATA register: (0x01) OK
[PIA] Wait for IRQ ... Got it
[PIA] Read STATUS register: (0x05) OK
[PIA] Check status: Ready and enabled
[PIA] Init was successful
PIA has enabled the SCSI interface
Boot complete
Starting taskrouter
[Task router] Prepare for next task
[Task router] Idle
Hardware: V2.0, Firmware: V1.0 (Build: 2011-04-25T00:07:43 UTC)
Init target:
Target POST:
SRAM test ... OK
POST complete
PCMCIA card found
Init PIA:
Boot complete
Starting taskrouter
[Task router] Idle
[Task router] An initiator selects us
[Task router] Connected to initiator with SCSI ID 7
[Task router] I_T nexus established
[Task router] ATTENTION condition detected
[Task router] Receive message from initiator
[Task router] Message: EE
[Task router] IDENTIFY message received
[Task router] LUN 14 selected
[Task router] I_T_L nexus established
Init target:
Target POST:
SRAM test ... OK
POST complete
PCMCIA card found
Init PIA:
Boot complete
Starting taskrouter
[Task router] Idle
[Task router] Message transmission error
[Task router] Release SCSI bus
[Task router] Idle
