Mac OS on ANS - Modding a ROM DIMM
@Big Ben - would you be willing to document via shaky-cam mobile phone and upload to YouTube or Internet Archive and show the bootup/build process???
Thanks!!!
I’m afraid there is nothing special about booting MacOS it just boots like any other Power Mac: grey screen, happy mac and so on.
Open Firmware stuff was related to improper configuration.
Front LCD screen is disabled so nothing to see here too.
As far as building a ROM DIMM, I won’t be able to build others until someone design a new pcb board.
I just wanted to say thank you to Big Ben, John, joevt, stynx, dougg3, Eric & jocketlill.
It is absolutely amazing to see everyone come together to make something amazing happen!!!
If anyone is thinking about making a custom rom board, let me know. I was thinking of reaching out to Joe to see if we could get a blank SIMM created.
I forced the boot into Mac OS with setenv boot-command bye
Now the ANS just boot like a normal Mac. To boot AIX I suspect you only have to press Command-Option-O-F and type boot to start AIX.
I tried to install a video card but it wasn't detected, maybe a bad contact or a non-working card as it was untested.
Fun-fact the Cirrus Logic 54m30 chip is limited by... software and hardware (sort-of), because the chip is designed for little-endian operations and the driver lack implementation of endianess convertion.
Source: https://wiki.preterhuman.net/ANS_Hardware_Developer_Notes - page 9 section 2.8
Doc also contains CPU board pinout!
On that note, I ended up making an OpenFirmware driver for the Cirrus Logic GD54{30,34,36,46} cards based on the FirmWorks codebase and some taking apart of the ANS code.
It seemed to work fine when I was emulating the Viper CHRP firmware.
If it's useful for anyone else, here you go.
On that note, I ended up making an Open Firmware driver for the Cirrus Logic GD54{30,34,36,46} cards based on the FirmWorks codebase and some taking apart of the ANS code.
The ANS code has one fcode image for the GD5430. I would have just used that to create an fcode image for a PCI Option ROM but some additions/changes would be needed to handle words that are in the ANS ROM but not part of the Open Firmware spec.
Your ROM is currently set to compile for GD5446 (sets the device ID in the fcode image of the PCI Option ROM to 0x00B8) but all the variants (GD54{30,34,36,46}) are handled identically by the code. They don't have differences that matter for the Open Firmware driver?
Do you have more details about this? What emulator? What virtual hardware? What OS or just Open Firmware?
Not really. The GD variants just have different VRAM amounts for the most part. Ideally the ROM variants could be handled better with a better makefile, but I wrote it in my spare time during Winter break.
I hacked together a QEMU that *mostly* boots the CHRP Viper and Cobra ROMs (I couldn't get the timing down for deserializing the weird bitbang DIMM/SIMM presence thing and actually implement the device model for that properly, so I patched 2 words to get past the memory sizing sequence.). Enough to the OF "ok> " prompt anyway.
I tried it with the FirmWorks PReP firmware as well. It "works" on both implementations.
bitsavers website has PowerSurge Flash ROM pictures and schematics.
http://bitsavers.org/pdf/apple/powerpc/PowerSurge/ROM_Flasher/
@joevt,
I just found this thread. I wish I could keep track (and understand) of all that is going on with PPC ROMs and how to flash them.
I still have a working ANS ROM SIMM that boots MacOS 8.6 and I guess MacOS 9.X (I haven't tried that) and I would love to make additional ROM SIMMs for anyone that wants one. I just don't know how.
First question, from this thread I see the images of the Flashgordan board. It appears that is was made my Apple, correct? Is there anyway to obtain one?
I have 32 AM28F020-90JC that I got from UTSource. I had planned on flashing them one by one because all I have is a TL866II Plus. If the Flashgordan board is available it would make dups much easier. I also received a different ROM SIMM from ClassichasClass that has 4 ROM chips (2 on each side) and if that can be flashed with the ANS MacOS code all the better.
Lastly, I don't remember or can find the OF commands to determine the exact ROM version. Would you mind helping?
adios,
jt
Probably not. You probably have to make your own or use a different flashing method.
Do you know if it's 5V or 3.3V? Is it 4 MiB? Since it only has 4 chips, it's probably not programmable by Apple's Flasher utility without creating your own flashing code. Apple's Flasher utility is useful only if you can boot with the ROM SIMM connected. If it's in the ROM SIMM slot, then it needs a bootable ROM to already be flashed, or it needs a switch to switch between two versions of ROM. The Flash Gordon board connects to a different slot (NuBus?), and the flashable ROM SIMM connects to that.
The version should appear when you enter Open Firmware. One of the device nodes may have a version property.
Capture the output of dump-device-tree to see all the properties of all the devices.
In Open Firmware, get and verify all the checksums from the ROM using the code at:
https://tinkerdifferent.com/threads/apple-network-server-macos-based-roms-found.4756/post-41390
I wonder if booting into single user mode would work without a proper video card?
@adespoton,
I have the infamous ANS MacOS ROM SIMM. My ANS 700/200 boots directly into MacOS 8.6. This was the current MacOS version at the time I received the MacOS ROM SIMM from Apple Business Systems engineer on the down-low. The ANS has Apple stock parts, 5 9GB Hard drives, an Apple 10/100 pci card & an IOGear USB 2.0 pci card. The drives are arranged in a RAID 5 setup using the MacOS Softraid software. The video is the stock built-in with no mods.
I recently found the IOGear USB card on eBay for about $20 for use with one of the ANS prototype Deep Dish systems I have also.
I am attempting to find a way to duplicate or create MacOS ROM SIMMs sourced from the working ROM SIMM I have,
Heh. I tried to make an ANS to Mac CPU card adapter back around 2000 - 2001. Didn't work, but then my skills at the time were rudimentary. Might be worth another try. To begin with, it should be at least a 4-layer board. But back in 2000 4-layers at that size would have cost well over $1000 for a prototype.
Wow.
I won’t call that rudimentary!
That would be a nice adapter to have, but I suppose the socket is hard to obtain nowadays…
Wow.
The through hole socket, which that design used, seems to be unavailable. I knew a source as of a couple of years ago and posted it in a Tinkerdifferent thread. Either the supplier got rid of them, or someone bought up all the stock after following my link. Similarly for the surface mount socket, but I found a large supply of those at a different supplier. Won't be mentioning where...
Ya know I was thinking the other day about if the normal Mac style processor cards would work, this definitely tells me it wouldn't just be plug n play hahah.
If you ever get a more modern design made, definitely let us know, wouldn't mind using a 400mhz card haha!!
So as per the tinker different fourm post, and my own findings, the prepro roms (1.1.20.1) will be better for speed, than the 2.0, because the 2.0 roms dont address cache properly.
That being said the 2.0 rom is much more stable, and makes the internal scsi, internal gpu, and internal networking work, whereas the prepros don't.
My major usecase is Debian, so hopefully it makes that faster. i have a 128 n ethernet card, so imma do the prepros.
Perhaps the ROMs can be reverse-engineered and the 2.0 ROM can be fixed to properly address the cache?
c
Im sure this is reasonably trivial for some of the folk here, but i think the biggest issue with doing that currently, is that no one has a rom sim that has hotswappable chips yet. along with most people not having the specifc programmer or whatver.
In other words, the ability to program a chip exists, but not in an efficent enough way to make it easy enough to be worth.
Currently that would have you desoldering chips more than once, and from my experience the roms will pull pads easy, so its just not easy rn.
c
From the tinkerdifferent forums, from "classic has class"
"It's not understood right now why it doesn't properly handle the cache. Repeatedly flashing the ROMs to test guesses isn't anyone's idea of a good time. I don't think this can be easily solved until we get the ANS emulated, which I know some Smart People(tm) are looking at, but doesn't yet exist.
My main interest is to get 1.1.20.1 to be a better host for OS 9, and that will involve some minor modifications to the operating system - which I suspect was done to whatever version of MacOS Apple demonstrated on them back in the day. That's a more achieveable goal for me, at least for the moment."
i ordered some rarer socket type things for the rom chips, trag has mentioned they havent gotten them to work, but i think pressure is the issue and a binder clip would solve any issues.
I wouldnt mind the look, for the ability to not have to solder any new chips on. according to trag, the rom boards realllly dont like getting soldered on more than once, at least via heat gun.
Both in mine and his, its been found that at some point the board will just...not work, even though visually everything is fine.
I plan on making remakes of these boards with we# and reset# tied to Vcc already, so all you should have to do is solder chips on.
