Roger Wilco Requires:
System 7.1 or later
2 Megabytes free disk space
1.5 Megabytes free memory
Appearance manager 1.03 or later (see note 1)
Sound Manager 3.2 or later (see note 2)
Note 1:
Appearance Manager is bundled into MacOS 8.5 and above. If you have MacOS 8.5 or above, nothing additional is required.
Note 2:
Sound Manager 3.2 is included with QuickTime 3 or higher. If you have QuickTime 3 or higher, nothing additional is required.
If you're running a version of MacOS earlier than 8.5, the Roger Wilco installer will install the necessary Appearance Manager items for you. It will NOT install the Sound Manager extension. To check your version of Sound Manager, find the Sound Manager extension in the Extensions folder of your System Folder. Click on the icon and choose "Get Info" from the File menu. It needs to be version 3.2 or later.
