Anonymous Freak
Okay, one of them isn't a 68k, but two are, so I figured it belonged here rather than the PPC 'books section. (Plus, the Duo 2300c is basically just a 68k logic board with a PowerPC stuffed on it.)
Got all three cleaned up, got all my docks lined up, so decided it was a good opportunity to take a family portrait.
From left to right:
Duo 230 - the top end of the launch Duos, with 4 MB RAM. Plugged in to a Floppy microDock, with another Floppy microDock in front of it. Using the official Duo power brick.
Duo 280c - the top end of the 68k Duos, with 40 MB RAM. Plugged in to an E-Machines EtherDock (really just an Apple miniDock with the modem replaced with an Ethernet card/port. You can even feel the place for the Apple logo under the E-Machines sticker, and the modem symbol under the Ethernet sticker,) with an official Apple miniDock in front of it. It happens to be using a power brick from a PowerBook 1400c.
Duo 2300c - the last of the Duos, the 'crown prince' of the line, and the only PowerPC of the bunch. Launched at the same time as the PowerBook 5300 line, it had the same power as the 5300/cs/c in the Duo package. This one has 40 MB RAM, and is in a full size Duo Dock with color lid upgrade. My Duo Dock doesn't have Ethernet or a hard drive built-in, but I did throw a NuBus Ethernet card in a while ago.
Sadly, only one battery holds any charge at all (basically exactly enough to wake up from sleep, then give you the 10 second warning.) One battery claims to be fully charged, but if you leave it in for more than 15 or so seconds, it starts making a whining/screeching noise, so that one doesn't get left in! The last one causes whatever system its in to crash the moment the electrodes make contact!
From left to right:
