sweet thanks a bunch hopefully all that needs dealing with now is the battery and Hard DriveI have a hole box on PB 1x0 series part's in to loft, I'll have a look at some point in the next couple of days and see if I have the parts you need
Thanks i thew out the original battery and hdd but im sure i can find another somewhereDo you have the original battery? If you do your best bet would be to re cell it, If not tbh I wouldn't worry about the battery, the 1x0 series will run just fine off just a AC adapter. The HDD is a bit more tricky as the 2.5" SCSI drives are very hard to come by, there is the SCSI2SD powerbook edition which will probably be your best bet
It might be the weekend before I have a chance to dig up the box of 1x0 series parts but I'll let you know once I have
its OK if the brass mounts are still in there i can gorilla epoxy them in place also im considering building my own LCD cable tooJust had a look, unfortunately the only lid's I have got have broken screw mounts (I guess that's why they are spare) and I don't seem to have any LCD cables at all.
I'll have another quick look around as I am sure I had more parts than I have found but I am not hopeful that I'll find anything else
damn.... well ill have to keep a look out for one do you have an EMI shield thingy though?Brass mounts are missing unfortunately
that sounds Great! however im not quite ready yet if you could keep it asside for me that would be aceYeah I do have the EMI shield, If you want it you can have it for the cost of shipping
sorry for the absence again that sounds great but sadly im unable to figure out how shipping works (i have autism and haven't shipped parts yet)I found a lid! It was of course in a draw of completely unrelated parts
If you want it it's your for £5 + shipping
