Hello,
Let me tell you the terrible tale of the bombed Quadra 700.
Do you feel that sensation traveling your spline? Fear! You name it!
That’s the feeling I had when I took off the shelf this freshly bought Q700 and I heard something moving…
Removing the top revealed what everyone fear the most… an 1/2AA battery socket loaded with a bombed Maxell floating around.
Damn it! Let’s remove the PSU and the drive holder to get a sneak peak of the carnage…
Well this isn’t that bad! Is this Quadra 700 the first Mac I’ll actually save from a lithium bomb?
Some cleaning after it looks quite nice! Almost everything fall off and a bit of work with a spludger and the iron did the rest.
I won’t say it looks like new, but it is quite nice!
With a bit more solder iron work I managed to clean the battery support viad and holes.
Except I ripped off the ground pad on both sides, it was too damaged.
But does the inner still work? Does it need a wire patch?
Let’s find out! Taking the multimeter in continuity mode I connected both probes and it ringed!
Hourra! Another ground test, it still ring hourraaa….. ay?
Wait.
I messed up, this pin on the molex is not the ground.
I moved both probe to the two molex on the board, both have 5V and GND shorted.
Damned.
Slowly I removed each tatalium capacitor I found on the 5V rail, hoping it was just an old cap failure…
Except it’s still shorted and caps where fine.
A "short" lived victory against the bomb, a long battle now begins to find the short…
Wait.
Damned.
