Logic Board reworking: A Tale of Two IIcx
Addicted
Not really sure of how to debug a PSU, but I have it 'exploded' for probing. Makes me nervous to have it there, guts open to any accidental contact! I've done all the basics I know to do: continuity testing, reflow, check for shorts. It does provide a clean 5.199V on the trickle rail. I recapped it months ago.
It was doing the relay click-loop until it failed, probably a big clue. Something was out of spec, and it finally failed completely?
Idea #1 today is to pull the relay (after I unplug the PSU for an hour or so) and test its coil and points. And maybe the relay coil has a snubber or diode - built in or on board - that's shorted out. No idea.
Idea #2 is to re-confirm that the logic board is raising #PFW (easily done), but the logic board boots with a different PSU - so that's likely OK.
The large daughtercard in the PSU is beyond my pay grade, sad to confess.
Addicted
Relay is good. Oh, well.
Skipped lunch, extracted and took photos of the daughter card. It has pencil markings on it indicating the values of a few caps and resistors, on the right hand side of the photo. Either they were written by the assembly engineer, or I am not the first to open this PSU. The black/white pair near the ASTEC logo are to the thermostat. The ICs are (clearly) an LM393 and a 3842N PWM generator. Identifying the transistors is next on my list, although the SMDs may not be 100% identifable.
Addicted
OK, it's the PSU. It's driving 13.5V onto the #PFW line, with or without a logic board.
I replaced a triac and two power FETs in the PSU before I knew #PFW was over-voltage, because I was in there and had the exact replacements already on hand. It was a simple swap and I hope I did not introduce this with them. Removing and replacing the daughter card was still good to ensure clean solder joints and unbroken pads, but still.. fogged up the debug with unnecessary changes.
Nice to have a lead; perhaps I can trace this back into the PSU somehow.
Addicted
The saga continues 🙂
The first unit remains absolutely stable.
The second unit has two issues.
First and foremost, the PSU remains dead. I recapped it a while ago. I overhauled it including down to the daughter boards and found possibly cracked high-wattage resistors and a very discolored Zener, and replaced other identifiable parts while there. But I have no experience in power supplies, so this was hit or miss, and came out miss. The PFW line still has about 13V on it. With no evident shorts anywhere, and my recap parts all in the right polarization, I can't imagine where this bleed is happening.
The second problem has slightly improved. The system sad chimes before it inits video if I boot with the onboard ROMs. If I boot with the CayMac ROM SIMM, the system runs almost perfectly. When running MacTest IIcx V2.0, it used to bomb as soon as it tried to play the Standard A-chord. After more cleaning and resoldering around the ASC (UF14 and UF15 might have been cap-corroded just a bit), it now just never finishes that test and never plays the chord. The cursor remains responsive, but clicks on Pause or Stop do nothing. But no Bomb.
I have had that copy of MacTest do other weird things; it may be corrupted. I am having trouble finding a different download of it or any more advanced Apple-produced IIcx diagnostics.. I keep finding bad StuffIts, etc.
Next time I get this out, I want to totally clear my tiny bench and use a good Mac to host AppleCAT on the sad IIcx. Perhaps it can turn up some details.
Addicted
Using knowledge gained from other IIcx restores on this site and with links provided by @SuperSVGA , progress was made on the remaining sad-chime IIcx.
For other novices such as myself, the Test Manager is a serial debugging tool in the ROM code. A thorough guide to it can be found here - be sure to read all the sheets.
The IIcx I am restoring currently sad-chimes immediately at boot, but will boot with a ROMinator SIMM. Even then, it eventually seizes up after a little while.
Using Test Manager commands, it appears to be a ROM checksum failure. While I had the logic board on the bench, I issued a few more commands to verify that the 4MB of RAM I have in Bank A looks good, since I had to replace the banking gates. Starting right after a cold-boot sad chime, first the ROM smoking gun:
Code:
*A
*E
0000FFFF0001*R
000400010001*T
000000080000*R
Then the RAM validations:
Code:
*4
00000000*0
003FFFFC*1
000200010001*T
000000000000*R
000000010001*T
004000000000*R
*4
00000000*0
003FFFFC*1
000300010001*T
000000000000*R
I may not be interpreting the *T0004 test correctly. The return code here may indicate which ROM lanes failed or (more likely) it may just be the ROM size. But the result code upon entry was 0x0000FFFF followed by 0x0001: ROM Checksum Error.
I've already re-soldered the ROMs, but I'll check the traces to the CPU again.
I hope to find (or blast my own) Apple-bit-loyal ROMs to replace any failing ones; hopefully only one is bad. After that, the only mystery remaining is why the system locks up after a little runtime. (And, it still needs a power supply.)
Addicted
After more study of the existing posts, I think the ROM Checksum Test (*T0004...) '8' is telling me that the LL ROM did not match its checksum. I like the ROMinator I have, but aim to have as authentic an antique as possible. So off to investigate a replacement EEPROM and conjure up an ad-hoc programmer for it while I wait. I'll run the same test on the other IIcx first to be sure I have a valid source for the bits, but that Mac boots effortlessly and is very stable, so the validation is mostly a formality.
I declared defeat on the ASTEC power supply, which after rework is still driving 13V or so on the PFW signal line. Double double checked that I have the connector orientation correct and that I am not measuring the 12V output by mistake ✔️ Found a replacement online; awaiting delivery.
Addicted
The second IIcx now happy-chimes with no ROMinator.
I dumped my ROMs with Test Manager and compared them to a reference ROM file, and sure enough, 64 words had the highest-addressed byte corrupted. The low nibble was always the cause.
I live a short drive/medium walk from Jameco Electronics (*), and they had 27C512 70ns EEPROMs in stock. I bought four, and since only UV-eraseables were in stock at less than 120ns access time, I bought sockets.. cuz, seemed contrary to solder-in a reprogrammable part.
A quick Python script to pull the correct lane out of the Archive.org ROM file for the IIcx, flash the chip, and done! Happy chime with 8MB spread 4/4 across both banks.
In days past, that IIcx was still locking up after some use, but did not try to reproduce that and called it a day after getting my happy chime. Ended my Tuesday on a high note (pun intended). Debug that another day. I suspect it's something to do with audio out, as it will cruise right along until I trigger an alert or ask the diags to test sound.
(*) I think it was 1979. I saw an ad from Jameco Electronics in the back of BYTE Magazine, and with the money I had saved working at a theme park that summer I sent a money order to Jameco to buy eight 450ns dynamic RAMs to bring my Apple ][ (S/N 11444) up to a whopping 32KB.
Callan
It would be dangerous for me to be that close to Jameco! Definetly jealous. There are very few places to even drive to get parts nowadays. Luckily, Mouser is normally next day delivery.
Great troubleshooting!
Addicted
@Callan - for a while, I lived four blocks from a Fry's Electronics. In the 90s and early 2000s, they still sold - retail - everything from 7400-series chips to CPUs, oscilloscopes and static RAMs. They folded a few years ago, sad to say. The real loss out here was when WeirdStuff Warehouse closed. It was a huge old shed stuffed with SIlicon Graphics, Apple, Sun, all manners of legacy hardware, some working, some not, for next to nothing. You could find basically anything there.
Addicted
And the saga .. CONCLUDES 🔔🔔🔔🔔
The second IIcx was up and running and playing sounds for about thirty minutes just now. It's late so, I'll do a more proper burn-in tomorrow.
What changed?
I was almost asleep when I had a vague memory that if I boot through a ROMinator II into System 7.1 or later, I needed to patch the Gestalts, something like that.
But I never, ever got around to that.
And now that I had discovered and replaced my corrupted on-board ROM, I could boot without my ROMinator II, and without those patches.
So I tried. Booted into System 7.5.3 on an external SCSI with the RasterOps video card, VM and Mode32 .. and played Maelstrom for a few minutes. Total time warp back to wasting time in college...
The sound was scratchy, but I already know that the speaker's pigtail contacts are green and need to be replaced.
Then ran the full Speedometer benchmark with the RasterOps 8L set at millions of colors.
Set up PRAM, chose a desktop pattern, SetDate into 2025 :) etc
Then poked around in the Sound Control Panel, trying to force the hangs I saw before. They didn't happen.
Then confirmed soft PSU power control by using the Apple Menu •Shut Down option, which worked.
I think I can look forward tomorrow to putting this IIcx logic board back into its chassis with its hard disk scaffold and floppy drive - and finally put the lid back on the chassis. Just need that replacement PSU to arrive and it'll be real.. after a year of occasional restoration work.
This forum, its participants, Macintosh Garden, the Macintosh Repository, TinkerDifferent, so many thanks I need to hand out. Cheers!
Boctor
That's an encouraging find with the ROM itself actually being dodgy, well done! Did you need any special tools such as a hot air preheater, to coax the DIP out of the board? I'm interested in getting the same socket and a ROM/programmer from a supplier in the future, for a IIcx whose onboard ROMs fail the same critical test (Returns a '2' where yours had an '8'. This supposedly means the second chip, MH, has a bad checksum.)
Slight tangent, but the mention of Fry's brought back sad memories of my final visit. The staff were instructed to tell customers asking about the empty shelves that they were "changing suppliers," without further elaboration.
Arbee
Fry's was legendary back on the pre-1994 Internet, and it lived up to the hype when I actually got to go to one in early 2003 (the San Diego Mission Valley location). MicroCenter is the closest thing to it that exists now, but they don't carry loose chips or anything like that.
I'm a little surprised the ROM itself was bad rather than a solder joint or something, but these machines are certainly at the age where anything can happen.
Addicted
@Boctor - I evacuated the solder from 26 of 28 pads by applying a little flux, heating the joint, and wicking the easy parts away, then repeating where needed using a simple thumb-pumped solder sucker instead of wick. The last pins, Ground and Vcc, had too much copper nearby and resisted several repeats, and I direly wanted to avoid lifting the pads and traces. I sighed and sacrificed the old chip -- clipped those pins from above, then tweezed them out while heating the pad from below.
It would have been nice to keep the intact chip around like a little paperweight to remind me of this adventure - I think this is the first time I've seen a mask ROM incontrovertibly be the problem.
I feel so lucky that none of the corrupted bytes ruined the Test Manager code, which was the major catalyst in helping me find the matter with this board. I'll tidy up the diffs I made (add the addresses/offsets for reference) and post them here later today, purely for the curious. Those with disassembly listings might want to know what toolbox etc. routines were corrupted.
While on the way to Jameco to pick up the EEPROMs, I thought about what I might need to build my own flash burner. In the interest of time, I just got a cheap ready-made one while there. I have needed one for a while, and will get the value out of it.
Addicted
Corrections to my sleepy-eyed success post:
The patches I mentioned are necessary only for System 7.5 and beyond, I think. I recalled it incorrectly as System 7.1 and beyond last night.
My RasterOps 8L doesn't do Millions of colors. I did expand its VRAM to the max, but without the ROM from a 24L that only enables a larger, virtual, pannable screen in 256 colors. I got confused because Speedometer produced a 16-bit benchmark result, somehow.
Addicted
FWIW, the comparison of the factory ROM contents versus what my ROMs had.
You can see that with only two exceptions, they happen on 0x__700 and 0x__F00 boundaries; each fault persists for eight bytes. Possibly the 27C512 page (row) size.
They always happen in the right-most byte, which is the IIcx's LL ROM. Errored bits flip both ways, not always to one or always to zero. It's as if the ROM has changed the low nybble to be 0x6 in those ranges.
The error-free word at offset 0x035710 is curious. The correct LL byte there is 0xC6, and so the theorized error did no harm. That coupled with the first two isolated errors may shine some light on the fault for those savvy with the EEPROM internal buffering and layout.
Code:
OFFSET   CORRECT   FAULTED   (XOR)
        H M M L   H M M L   H M M L
         H H L L   H H L L   H H L L
007B48: B2680006  B2680002  00000004
024468: 16505C4F  16505C4D  00000002
034700: 036D0374  036D0376  00000002
034704: 037A0384  037A0386  00000002
034708: 038D0391  038D0396  00000007
03470C: 0398039D  03980396  0000000B
034710: 03A203A4  03A203A6  00000002
034714: 03A603AB  03A603A6  0000000D
034718: 03B203B7  03B203B6  00000001
03471C: 03C403CE  03C403C6  00000008
034F00: 00180000  00180006  00000006
034F04: 00000180  00000186  00000006
034F08: 00000000  00000006  00000006
034F0C: 00000000  00000006  00000006
034F10: 00038000  00038006  00000006
034F14: 00000000  00000006  00000006
034F18: 00000000  00000006  00000006
034F1C: 00000000  00000006  00000006
035700: 0079AB2C  0079AB26  0000000A
035704: 032B3424  032B3426  00000002
035708: 24DA0019  24DA0016  0000000F
03570C: 83300000  83300006  00000006
-                                    ;; Curious
035714: 2CC0169E  2CC01696  00000008
035718: D9800003  D9800006  00000005
03571C: 30010C00  30010C06  00000006
035F00: 01070104  01070106  00000002
035F04: 01070108  01070106  0000000E
035F08: 02080108  02080106  0000000E
035F0C: 01080108  01080106  0000000E
035F10: 01080108  01080106  0000000E
035F14: 01080108  01080106  0000000E
035F18: 01080104  01080106  00000002
036700: 00000000  00000006  00000006
036704: 00000000  00000006  00000006
036708: 00000000  00000006  00000006
03670C: 00000000  00000006  00000006
036710: 00000000  00000006  00000006
036714: 00000000  00000006  00000006
036718: 00000000  00000006  00000006
03671C: 00000000  00000006  00000006
036F00: 0F0000FF  0F0000F6  00000009
036F04: F0FFFFF0  F0FFFFF6  00000006
036F08: FFFFF000  FFFFF006  00000006
036F0C: FF0F00F0  FF0F00F6  00000006
036F10: FF00FF00  FF00FF06  00000006
036F14: F0000000  F0000006  00000006
036F18: 000000FF  000000F6  00000009
036F1C: FFF0F00F  FFF0F006  00000009
037700: 015F0163  015F0166  00000005
037704: 0168016F  01680164  0000000B
037708: 01740178  01740176  0000000E
03770C: 017C017F  017C0176  00000009
037710: 01800183  01800186  00000005
037714: 01880188  01880186  0000000E
037718: 018D0192  018D0196  00000004
03771C: 0197019B  01970196  0000000D
037F00: 00000000  00000006  00000006
037F04: 00000000  00000006  00000006
037F08: 00000000  00000006  00000006
037F0C: 00000000  00000006  00000006
037F10: 00000000  00000006  00000006
037F14: 00000000  00000006  00000006
037F18: 00000000  00000006  00000006
037F1C: 00000000  00000006  00000006
Boctor
Thanks, I may stick with using the ROM SIMM slot for the time being, knowing that. After my fight with the axials, I think further through-hole on the IIcx will require some more practice. Even with a desoldering gun, I was pretty much scorching the pads around those holes before their contents would fully melt, so those power/ground planes in the middle layers must be seriously beefy.
Addicted
The IIcx with the replacement LL ROM was fine until I fumbled while removing the 12" video card, and the front corner of the card struck somewhere in the ROM and developer button zone as the Nubus connector lifted free. Then, no chime.
The system would still boot fine with a ROM SIMM. (Whew)
I saw no obvious scars. I removed the remaining three original ROMs. Getting better at removing through-hole parts; working very slowly, I freed all three without damaging the board or the parts. Final step was to use a narrow-nozzled heat gun on the difficult Vcc/Gnd pins and ease the chips out.
This allowed me to use the blaster to verify them (3x each); no new bitrot. No internal damage. It wasn't the ROMs.
Continuity checking the ROM pin holes with the ROM SIMM contacts was also good, so I hadn't scratched or fractured some trace. Also ROMSEL (/OE) checked. Power and ground, check. I made the ROMs consistent by adding sockets for the three old mask ROMs, to match the socketed EEPROM. Checked continuity between the ROM SIMM socket and the new sockets' pin pits, all good.
Replacing the old ROMs into the new sockets returned the system to booting from the onboard ROMs. The impact of the video card must have only shattered one or more old solder joints among the ROMs. Way back during recapping, I replaced an old cap near there that may have aged those joints. They're all freshly soldered from scratch now, plus the ROMs are all socketed. It's more future-proof than ever 🤓
Moral of the story is that a decent-looking solder joint can still be frail.
Addicted
tl;dr: what is Test Manager major error code 000F ?
Both IIcx's were stable, and the one with the ROM issues around cap C4 was fun with its million-color RasterOps card. But it regressed last night.
It boots, happy chimes, the RasterOps card does its animated splash screen - then the system appears to reset, happy chime again, then sad-chimes while the RasterOps card is performing its splash screen. This leaves a corrupted, partial splash on video.
I booted headless (video card removed), same boot-reset-sad pattern but more rapidly, as the RasterOps animations no longer consume cycles.
Here's my question: checking with Test Manager at this point, I consistently get a response code of
00000003000F*R​
but none of the Test Manager guides I have list a major error code 000F . So, if anyone knows the 000F code.. or can just punch me and show me where I overlooked its description.. I'd be grateful.
In case I am having another brain-dead day, if the major error code is the 00000003 .. that would be RAM Bank A. I ran the mod3 memory test on all memory (4M A, 4M B) plus the address and data line tests; all pass.
I swapped the SIMMs between the banks and saw no difference. I emptied Bank B; no difference.
Booting the ROM disk in the CayMac ROM SIMM 'works', all SCSI devices appear and mount, but before long the system locks up. Booting System 7.5.* from internal or external SCSI locks the system up just after the "Welcome to Macintosh" graphic appears, with no cursor on the screen. I reset PRAM in case this is somehow a 32-bit issue; no change in outcome.
