Ouch! Couldn't have said that less clearly it would seem.
Lets try that again:
SE/30 Video is interacting with CPU, A/B and MIA standard Neck Board, doing its 1-bit VidCard thing in PseudoSlot $E memory space as always.
Color30 is building exactly the same image in parallel on the PDS in Slot $whatever memory space, but in 8-bit depth.
Color30 is monitoring/shadowing memory activity between built in video system and main memory/CPU as it fills its VRAM buffer with the 8-bit version of the SE/30.
It's a symbiotic relationship between the two video systems until the Color30 cuts the standard neck board feed off at its knees on the A/B, letting what looks like five lines interact with the Grayscale Neck Board while substituting its modulated grayscale feed over what looks like a pair of lines from the Color30 connector to paint the grayscale image on the CRT in perfect sync with what would have been a B&W stream of same.
Not sure which is a ghost or shadow image, but it looks to me like you can't really have one without the other, at least not without possible damage the A/B Bolle has been talking about.
On another note: I see two versions of the Grayscale cards, one with a pair of crystal cans as on the 306-48 . . .
. . . and one with apparently none?
I wonder which is which and if 1024x768 is easier to couple with the standard video dot clock than is 640x480? Have we got definitive info on what model is 640x480 out and which is 1024x768 out?
Is there a crystal somewhere in the lower picture I haven't found? Maybe in the black box on the lower left corner? If not, this version of the card appears to be working off the SE/30's internal video clocking, etc. that I've put my head on the chopping block about in the jibberish laden WAG above? :blink:
edit:
@Cory5412 why are crosslinks working from content posted here, but not links from 'fritter content or elsewhere? Also, why do I keep getting that -200 error every time I try to upload an image. ISTR trag couldn't upload PDFs a day or two ago as well.
Just tried to upload that 139kb wiring harness file I snagged off 'fritter and got the same error.
