So i bought that Supermac thunder /24 (rom v3.00) to get better screen resolutions and to switch between them without having to play on the adapter switches.
Pulled the 8•24 gc from my mac IIci and put the supermac instead. Works fine and has good image quality, except for the horizontal waves that show up occasionnally and half of the screen that sometimes move for a tick.
I tried two other lcd displays, other apple multisync cables, reslotted it once and plugged it directly to the display(I use a display switcher). The waves are still showing up and the screen still moves sometimes.
Then I started wondering 'Could the problem be due to any component on the supermac's board?'
So I ask here to see if anyone knows any related problem that can be fixed for the Supermac, or what component could it be. I will try cleaning contacts first. I will maybe try recapping after if this can be my solution. Any answer will be appreciated.
